::::CODE READERS NEEDED::::APPLY INSIDE!
Old Aug 18, 2008 | 04:49 PM
zccr-xsi's Avatar
Default ::::CODE READERS NEEDED::::APPLY INSIDE!
ok so heres the deal im trying to find a code reader that can read ASM code base,so we can try to get the cel shift light fuction working in T/E.if u think your up for the job start working on the asm code for the cel fuction send it to me ill test it if it works ill be glad to pay a good price!FYI the asm code says the shift light works but theres no RPM box.
NOTE!!
if u cant help me out please dont waste my time by replyingif your not a code reader or know someone who is one!payment will be made on same day as i test it.
Old Aug 18, 2008 | 08:43 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: ::::CODE READERS NEEDED::::APPLY INSIDE! (zccr-xsi)
uhg, ASM. I will give it a whorl..
Send the code snippet you are looking at to sanimalp *_at_* hotmail.com if you could. I will worry about integrating the routine once I figure out what is there and what I might need as far as passed in data is concerned.
Old Aug 19, 2008 | 07:07 AM
zccr-xsi's Avatar
sweet just let me know what u need!like i said before the ASM will says the shift fuction works but there needs to be a rpm box added.
Old Aug 19, 2008 | 07:24 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Default Re: ::::CODE READERS NEEDED::::APPLY INSIDE! (sanimalp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp &raquo;</TD></TR><TR><TD CLASS="quote">uhg, ASM. I will give it a whorl..
Send the code snippet you are looking at to sanimalp *_at_* hotmail.com if you could. I will worry about integrating the routine once I figure out what is there and what I might need as far as passed in data is concerned. </TD></TR></TABLE>
bad new is there is no code....even though it says its implemented. just the option byte is there...DASHCELOPT @ 7FF0h
maybe try looking at some older ng versions (ng48, try2, etc..) to see if it got deleted somewhere along the way.
Old Aug 19, 2008 | 04:11 PM
zccr-xsi's Avatar
Default Re: ::::CODE READERS NEEDED::::APPLY INSIDE! (fastcrxsi90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcrxsi90 &raquo;</TD></TR><TR><TD CLASS="quote">
maybe try looking at some older ng versions (ng48, try2, etc..) to see if it got deleted somewhere along the way.</TD></TR></TABLE>
you the same fastcrxsi90 from pgmfi?
Old Aug 20, 2008 | 06:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">you the same fastcrxsi90 from pgmfi?</TD></TR></TABLE>
yep!
Old Aug 20, 2008 | 07:40 PM
zccr-xsi's Avatar
&lt;&lt;&lt;dohcef8si from pgmfi,
im trying to find someone who can help us out getting this cel fuction working.but hell good to know we got someone eles on here from pgmfi that has some type of know how on rom editing!!
oh btw i got that emulator up and running i had to turn off the high speed **** and it worked like a charm!thnaks again for updating and keeping t/e alive and weel!
Old Aug 20, 2008 | 08:51 PM
93turbo16's Avatar
I could probably lend a hand with it. I haven't really messed around with obd0 code though.
Old Aug 21, 2008 | 12:49 PM
zccr-xsi's Avatar
Default Re: (93turbo16)
well get with fastcrxsi and see what u can do if he or i test it and the cel function works ill pay u asap!
Old Aug 22, 2008 | 01:38 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (zccr-xsi)
what assembler are you guys using?
edit: this one... http://plit.de/asem-51/
Modified by sanimalp at 4:26 PM 8/22/2008
Old Aug 29, 2008 | 08:06 PM
zccr-xsi's Avatar
i think so but u might want to double check
karrar55
Aug 29, 2009 04:52 AM
G2_Fella
34
Jul 31, 2008 11:15 AM
97teg415
Jun 1, 2008 07:03 PM
vtechrex
Jul 10, 2006 06:21 PM
Mad Hatter
Nov 14, 2005 02:50 PM
