Is there a plugin for Crome Pro to use the ELD input for Wideband??
Old Jun 15, 2008 | 07:59 AM
RyanA's Avatar
Default Is there a plugin for Crome Pro to use the ELD input for Wideband??
Just curious if there is a plugin for Crome Pro to use the ELD (0-5 volt) input instead of the narrowband (0-3.8 volt) input on the ECU?
Ryan
Old Jun 15, 2008 | 08:16 AM
downest's Avatar
Default Re: Is there a plugin for Crome Pro to use the ELD input for Wideband?? (RyanA)
I asked about this a while back and got no solution for it. Kinda sucks because of the huge difference between the actual signal and what Crome sees.
Old Jun 15, 2008 | 02:36 PM
98vtec's Avatar
moderator emeritus
to my knowledge, there is no ELD or any 5volt input.
.5 - 3.5v is what i recalibrated my LC1 to and set the same voltages in crome. Reads perfect.
You may want to look into the TunerTee if you have an Innovate wideband.
Old Jun 15, 2008 | 08:09 PM
RyanA's Avatar
Default Re: Is there a plugin for Crome Pro to use the ELD input for Wideband?? (98vtec)
I'll use either a PLX or an AEM that I have laying around. I'm putting the PLX M300 on for right now.
On Hondata and some other software, you are able to switch the ELD input (0-5 volt input) to use as your O2 sensor input instead of the regular NB input. Doesn't look like there is a script out there right now so I'll use the regular NB input.
Ryan
Old Jun 17, 2008 | 10:34 PM
calvinPGMFI's Avatar
a coder can do it quickly with a rom patch..
ENABLE ELD WIDEBAND|DISABLE ELD WIDEBAND...
ask some coders on pgmfi forum.. only 2 bytes should be flipped.
Old Jun 18, 2008 | 03:33 AM
RyanA's Avatar
Default Re: (calvinPGMFI)
Thanks, Calvin!
Txdragon
Engine Management and Tuning
Mar 13, 2017 03:37 AM
lowtegsr
Jan 16, 2008 11:59 AM
rnbguy
Aug 19, 2007 12:43 AM
S2000Forsale
Honda S2000
Aug 3, 2007 01:22 PM
hatchinprogress
Mar 18, 2006 05:15 PM
