Kro with twm itb.
Old Jul 20, 2008 | 12:29 AM
ralph11sec's Avatar
Default Kro with twm itb.
i'm pretty a newbie tuning itbs,
so its now set up with alpha n, table columns are from 0%-100% with 10% incrementes, i've set the tps via the parameters so that it will see 0-100 on closed to full throttle respectively
i know tuning itb is very different to other NA tuning via map.
is my table column settings okay? or should i go for more precise tps values in lower tps readings, like 0, 2, 5, 7.5, 10, and so on, and then 50%, 100%. or is that a bad idea?
also, should i go after 13s, afr even at part throttle like 10% tps? because i know it sees little if not, no vacuum at all.
portenio78
Engine Management and Tuning
Sep 2, 2012 11:52 AM
Steeve_Civic
Jan 6, 2012 12:51 PM
TheSav
Apr 10, 2006 11:23 PM
