1G B16A - activate VTEC sooner
Old Jun 29, 2008 | 10:40 AM
mjohnson0725's Avatar
Default 1G B16A - activate VTEC sooner
Based on what I learned from my brother-in-law's dyno tuning session, VTEC can be activated sooner to produce higher (than stock) torque several hundred RPM earlier in the rev range. I'm not interested in spending the kind of money I think it would take to switch to OBD1 and add Hondata (which is what he did). Are there other good options to activate VTEC sooner in the RPM range for an OBD0 B16A?
Old Jun 29, 2008 | 11:36 AM
Sr420Det's Avatar
There are alot of vtec controllers out there. Im sure theres one for obdo but Ive only used em on obd1. Try the origanal buddy club for a cheap alternative.
Old Jun 30, 2008 | 05:35 AM
Default Re: (Sr420Det)
My understanding of a VTEC controller is that it only changes when the VTEC switches over, but will not do anything to adjust fuel, etc.
Are there controllers that will make adjustments to fuel and timing for OBD0 engines or are there companies that can program a chip for the stock ECU?
Old Jun 30, 2008 | 06:26 AM
Sr420Det's Avatar
The apexi unit can adjust fuel and automatically advances timing.
Old Jun 30, 2008 | 08:00 AM
Nice. So does apexi recommend intitial settings for fuel and ignition?
Do I <U>need</U> a little dyno time?
Old Jun 30, 2008 | 08:43 AM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sr420Det &raquo;</TD></TR><TR><TD CLASS="quote">The apexi unit can adjust fuel and automatically advances timing.</TD></TR></TABLE>
it advances and retards based upon what you do with the fuel
Old Jun 30, 2008 | 04:46 PM
Sr420Det's Avatar
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">
it advances and retards based upon what you do with the fuel</TD></TR></TABLE>
So if you add fuel it advances? or the other way around. Yes you would need some dyno time to obtain full benefits.
Old Jul 1, 2008 | 05:14 AM
Maybe I shouldn't assume this engine is switching at the correct RPM. At wide open throttle this engine switches around 5200 RPM. Is this when a stock B16A should switchover?
Old Jul 2, 2008 | 04:35 PM
Top Ramen's Avatar
Default Re: (mjohnson0725)
If you have not modified the motor to make it breath better, lower the crossover is not going to help you.
Old Jul 2, 2008 | 06:24 PM
calvinPGMFI's Avatar
Default Re: (Top Ramen)
there is no replacement for an chip/tune or ems...
Problem is that you don't switch maps when you engage vtec earlier.
crxhondata
Jul 23, 2008 06:41 AM
96_cvc_ctr
Jan 27, 2008 05:35 AM
yeah_its_boosted
Nov 2, 2005 09:34 PM
ef_hybrid
24
May 15, 2005 06:22 PM
b18crxturbonitrous
28
Sep 1, 2004 11:14 PM
