d16y8 and timing in hondata?
Old Jun 15, 2009 | 12:11 PM
khmoe's Avatar
Default d16y8 and timing in hondata?
Hi i have a d16y8 top on a d16z6 block in my 96 coupe EX.
I have been running p2p ecu and e-manager fine, but i wanted hondata to tune some more.
The orginal p2p map and retarding timing under boost has worked good, but when i bought the s300 i did not know ther was no map for d16y8.
Should i take the p28(d16z6) map en retard the whole map by 4*?
I also tried to set timming at 12* and i flashed it to the middel line of the first 3
" ||| | " the crack wheel is also from my d16y8 block. when i do that i have to put the dizzy all the way back, but on the p2p i only had to have it on the middel so somthing is wrong.
With my original p2p i'm at 12* with the dizzy at center, to get the same result with s300 i had to adjust the timming to 21*.
So should i take the p28 basemap and add 5* insted of retard 9*????
Thanx for any reply
Kristian from Norway
Old Jun 18, 2009 | 01:44 PM
khmoe's Avatar
Default Re: d16y8 and timing in hondata?
Anybody?
Any info.
What do you think of my base map?
Dizzy at senter were the orginal p2p ecu givs 12* ignition, but hondata needed to be base map at 21.5*
Old Jun 29, 2009 | 12:00 PM
d16y8turbo's Avatar
Bump, I need to know too. I was outside messing around with my new s300 for the first time and the "Set timing" only allows for 16 btdc...is there a way to make it recognize 12 degrees for the y8?
Old Jun 30, 2009 | 12:37 PM
khmoe's Avatar
Strange that nobody knows this.
Not a singel basemap for D16y8.
Old Jun 30, 2009 | 01:48 PM
d16y8turbo's Avatar
I dunno, i have a great tuner and all, who made my basemap for my y8, but he said my car was always off on timing.
Old Jun 30, 2009 | 04:01 PM
Spunkster's Avatar
http://www.hondata.com/help/smanager...sub=set+timing
Old Jul 1, 2009 | 05:46 AM
khmoe's Avatar
If i set the timming to 12* the dizzy have to be all the way towards the firewall. is that the right way?
to match the orginal p2p i have to have the timming to 21* And then the dizzy is almost in center.
Old Dec 26, 2009 | 04:53 PM
sicones's Avatar
I have been trying to figure out the same thing with a turbo D16Y8. Can anyone shed some light as to what is the best way to setup the ignition timing on a Y8. Should I be using a Z6 cam gear?
Does anyone have a S300 calibration for a STOCK Y8??
Old Dec 28, 2009 | 09:57 PM
MONSTERek4's Avatar
you better lower ur ignition on ur boost tables unless u daily drive q16 lol just sink ur dizzy toi the the base map its that simple
Old May 26, 2011 | 11:31 AM
markodude's Avatar
Did you ever find a solution?
Old May 27, 2011 | 05:24 AM
mtber's Avatar
Incorrect. Change the value in the box...
I have tuned plenty of y8 cars without issues with s300.
Sync the timing, setup the timing table as you would assume it should look like, put the car on a dyno & tune it.
Old May 27, 2011 | 10:09 AM
sicones's Avatar
Well after much research the best way to tune a Y8 is to use a Z6 cam gear and set the base timing to 16* like a Z6 or B series. Then you can use any of the P28 base maps provided with your tuning software and no need to mess with the timing tables.
Old Jun 2, 2011 | 01:50 PM
markodude's Avatar
Icon2 Re: d16y8 and timing in hondata?
Thats pretty much the setup I have and I cant get timing to match between the hondata ECU and the timing light. If I have dizzy all the way to the firewall I am still only at about 8 degrees of timing, when hondata says 16....
Old Jun 7, 2011 | 07:57 AM
QUICK8CIVIC's Avatar
Check your cam timing if it lines up..you may have jumped a tooth that's why your initial ignition timing is off..HTH
portenio78
Engine Management and Tuning
Mar 31, 2012 05:32 AM
khmoe
Jun 19, 2009 07:09 AM
speedjunky01
Aug 23, 2006 10:41 PM
