Where did you put your PLX sensor module
Old Jul 3, 2009 | 05:52 AM
uncledan's Avatar
Default Where did you put your PLX sensor module
Installing an s300 in a 2000 Prelude. We will be using a PLX afr sensor module for o2 sensor input, and af gauge. Where have you, would you, put the PLX sensor module? Where, how, did you route the o2 sensor wire bundle to get it into the cabin?
We solved the switched power connection for the module with a fuse tap. If you aren't familiar with this, it is a metal clip that fits over one spade of a fuse. It extends above the fuse so you can solder your power wire to the clip. Then just find a switched power source in the fuse panel. We are going to use the radio fuse relay.
anewman
Audio / Security / Video
Mar 2, 2011 10:14 AM
iKhmaiFoSho
Jan 6, 2006 01:56 PM
who-got-rice
Aug 23, 2005 05:05 AM
Spudddy
Aug 3, 2003 05:36 PM
