trouble shooting map sensor
Old Jul 8, 2009 | 07:50 PM
cleanazcoupe's Avatar
Default trouble shooting map sensor
okay guys my car was throwing cel number 3 wich is map sensor i went ahead and replaced the plug in top of the intake manifold and that fixed the problem, but now its throwing cel 5 with is also map sensor when i unplug the map sensor in the top it goes back to 3, so is there another map sensor in the motor that is not the one in the top??
Old Jul 8, 2009 | 09:28 PM
mtber's Avatar
Default Re: trouble shooting map sensor
1. Check the green ground wire for a good ground.
2. Check the yellow wire for a 5 volt signal.
3. Check the white wire for continuity to the ecu pin for map sensor signal.
Veggie Man
Sep 25, 2012 02:49 PM
aldong
Oct 8, 2006 06:15 PM
sleepin91teg
Aug 5, 2004 04:39 AM
