Wrong basemap?
Old Jun 16, 2009 | 12:12 PM
mark11017's Avatar
Icon2 Wrong basemap?
Picked up a d15b head for my y7, im using a chipped p06 with a y8 basemap from phearable. I originally thought that's what the head was when i order the chipset from phearable, so i ended up with the wrong basemap. My question for you guys is this basemap is obv the wrong one, and im almost certain that's whats keeping my car from driving. When i go to move it or whatever and hit the gas the car just dies or moves very slowly. I have the d15b basemap but im not to good with crome, can i just load it to the chip via usb? Or do i need to solder other things onto the board?
Old Jun 16, 2009 | 12:15 PM
mtber's Avatar
Default Re: Wrong basemap?
Is your check engine light on ?
If so, what codes are you throwing ?
Old Jun 16, 2009 | 12:25 PM
mark11017's Avatar
Throwing IAT and a code for vtec but the wire is not plugged in. As far as the IAT its just a matter of switching the wires around.
Old Jun 16, 2009 | 08:17 PM
NAcoupeNA's Avatar
you melted the iat and damaged the iacv. also remove q13 because its most likely burned up.
Old Jun 17, 2009 | 10:10 AM
mark11017's Avatar
How do you know for sure that's what happened?
Old Jun 17, 2009 | 11:22 AM
NAcoupeNA's Avatar
a program for a y8 will run an itr motor. Granted it'll surge like hell. It'll run. That's usually the end result Crossing those 2 connectors.
Old Jun 17, 2009 | 12:14 PM
mark11017's Avatar
it runs just extremely shitty, so what needs to be done to correct this?
Old Jun 17, 2009 | 06:45 PM
mtber's Avatar
Resolve your IAT sensor code.
Old Jun 18, 2009 | 07:42 PM
mark11017's Avatar
Would the intake air temperature sensor make the car act like this though..?
Old Jun 18, 2009 | 07:43 PM
pb16b's Avatar
yes. in some cases, it won't even run at all.
naterpatater77
May 8, 2009 11:11 AM
eastbobdam
Jul 14, 2008 05:18 PM
TcUiRvBiOc
Aug 16, 2007 03:54 PM
0334973
Mar 23, 2007 06:41 AM
