gsr obd1 question
Old Jun 22, 2009 | 12:15 PM
HarosGSRek's Avatar
Default gsr obd1 question
hey guys i have a question i just wanna double check on something.
i put a gsr motor (obd1) into my civic. im using the old d16y7 obd2 wiring harness on in.
my question is... will i run into any problems if i use obd2 to obd1 jumper harness and a p28?
ive heard yes and no from many people i just wanted to see if anyone knew for sure.
thanks guys.
Old Jun 22, 2009 | 02:04 PM
NAcoupeNA's Avatar
Default Re: gsr obd1 question
no why would u? just make sure u have an obd2a jumper harness
Old Jun 22, 2009 | 06:52 PM
HarosGSRek's Avatar
i used an obd2a to obd1 jumper harness. and yeah the iacv is giving me problems. i also had to extend some plugs. when i give it gas it revs up just a little then it cuts off.
Old Jun 22, 2009 | 08:28 PM
jdm inc's Avatar
is it a three wire iac? if so you need to convert it to a two wire and switch the pinouts around.
Old Jun 24, 2009 | 04:44 PM
Tomdata's Avatar
This is a good link for the 3wire-2wire conversion
http://www.ff-squad.com/tech/wiring/...-98_a-plug.jpg
Old Jun 26, 2009 | 08:20 AM
rick_rabies's Avatar
I'm not Rick!
he did convert it to 2 wire from 3 wire. with the conversion harness and obd1 p28 will he still have to do the crank signal trick?
Old Jun 26, 2009 | 10:02 AM
Tomdata's Avatar
no. the obd1 ecu does not look for the csf sensor
Old Jun 26, 2009 | 03:26 PM
Blown90hatcH's Avatar
CKF.....y0
Old Jun 29, 2009 | 08:41 AM
I'm not Rick!
right, obd1 is in the dizzy. we still did that trick and have obd1 to 2 conversion and switch the tps wires runs better but still feels like hes towing a trailer at 5k rpm and it seems maxed out and loud. and cel is on for manufacture igintion misfire....? any suggestions
Old Jun 29, 2009 | 02:13 PM
No CKF sensor isn't in the distributor. It isn't needed for the OBD1 ecu. You are thinking the CKP sensor that is in the distributor.
What code is on? Two wire switch on the TPS? why
Old Jun 29, 2009 | 03:01 PM
I'm not Rick!
yeah thats what i meant. original motor was a y7 with the TB that faces up and the butterfly opens backwards. dude put a gsr motr in. the engine thinks its wot when its shut. we switched it and it runs alot smoother but still feels like towing a train and maxes out at 5k rpm. il have him ina few minutes post the codes
Old Jun 29, 2009 | 07:23 PM
HarosGSRek's Avatar
alright so i got a few more codes from the last time we had it checked.
p1382 misfire/ignition
p0500 speed sensor
p0135 o2
p0141 o2
im gonna change the tb tomorrow morning see if the difference in tps sensors.
Old Jun 30, 2009 | 04:20 PM
Tomdata's Avatar
Originally Posted by Blown90hatcH
CKF.....y0
Splitting hairs??
Old Jun 30, 2009 | 06:42 PM
Splitting hairs??
Nope. Just clarifying for others out there on the most missed labeled sensor ever.
CivicTT
Jan 7, 2010 07:43 AM
bobjohnson
May 1, 2008 07:38 PM
2wheelhunter
Jun 4, 2007 04:18 PM
NA JDM GSR
Jan 6, 2007 11:29 PM
