Chipped p28 problem
Old Jun 12, 2009 | 12:37 PM
kentuckyhatch's Avatar
Default Chipped p28 problem
I bought a chipped p28 a couple months ago and the car ran great on it. No problems or anything. I put a/c and powersteering on it and a week and a half later the ecu won't start my car. It seems that it isn't sending gas anymore. I put my messed up p30 in it and it starts right up so I know it's the other ecu. My question is, how do you know if it's the ecu itself that has gone bad or the chip? I opened the ecu and didn't see any scorch marks or anything out of the ordinary. I put a second chip in it that is mapped for a turbo car and it didn't start the car either. Is it my ecu or could it be the chipping kit? Could it be the chip? Is there any way to test it all to see where the problem is?
Key points that might be helpful in diagnosing:
Cranks like crazy but doesn't start
Since the a/c and ps was put on, it has fallen on it's face 3-4 times
Idles have been steadily decreasing from around 1000 down to about 550
Starts on another ecu
Neither chip will start the car
No scorch marks inside the unit
Can anyone help meh? Thanks for any input.
Old Jun 12, 2009 | 12:57 PM
93turbo16's Avatar
Default Re: Chipped p28 problem
Does it throw any check engine lights and do you hear the fuel pump prime with the suspected bad ecu?
Old Jun 12, 2009 | 01:53 PM
Never threw any cels. I never heard the pump prime either but I live on a busy road so I can't say with confidence that the pump didn't prime. I did listen for it and didn't hear it.
Old Jun 12, 2009 | 09:26 PM
No one else with any input?
Old Jun 14, 2009 | 09:27 PM
Sl1ck09's Avatar
sounds like ur main relay. if its hot outside that happens. ur soldering joints need to be fixed. or try giving ur relay a good kick. thats what i did. worth a try!
Old Jun 15, 2009 | 09:36 AM
slow96lude's Avatar
It does sound like the main relay and maybe its just coincidence that when you put in the other ucu it starts up take out the main relay and resolder the all the points. look at them and see if you can see any cracks in the solder,
Old Jun 23, 2009 | 07:45 PM
Sorry I haven't checked this thread in a while. I lost hope that there would be help on Honda Tech.
Main relay? In the ecu or somewhere else? I've put the ecu in a couple times since and it still doesn't work. My car starts fine off the other ecu everytime so I'm going to rule it out as a coincidence.
Old Jun 30, 2009 | 09:03 AM
SC61HB's Avatar
I am also having somewhat of the same problem. My car ran fine on a Neptune tune, then one day the car started running like crap and would barely start. I would put in another ecu with a lower boost tune and the car would run fine. I have several chipped ecu's and have tried the chip in all of them and the car still won't run right. Is there a possibility that the chip went bad?
Sorry if you think I'm thread-jacking, but I believe this falls along the same lines as your problem.
Old Jun 30, 2009 | 10:05 AM
93turbo16's Avatar
Generally the chip won't "go bad". But it could have bad connection or possibly a bent pin.
If you are having problems with the car starting and/or having problems with the fuel pump priming then the capacitor in the ecu will more than likely need replaced.
Vtec140
Oct 3, 2017 02:15 AM
blackcivic11
17
Jul 24, 2009 01:32 PM
Guru Designs
Dec 29, 2005 01:11 AM
killalude03
Apr 23, 2004 11:34 AM
Turbo R
Dec 29, 2003 12:28 AM
