wonky idle
Old Jul 1, 2009 | 01:07 PM
keep_up's Avatar
Default wonky idle
just got my gsr started, it is its first ever startup and i put a p28 stock ecu obd1.. it idle normal for maby 5 seconds and jumps continuously from 500-1800 rpm...
whats going on?
also wont let me rev up the engine at all it will shut off.
Old Jul 1, 2009 | 01:46 PM
HRTuning's Avatar
Default Re: wonky idle
Idle - You're running a GSR on a stock P28.
Old Jul 2, 2009 | 04:52 PM
mtber's Avatar
I doubt the idle issue you have has to do with running a stock p28, however you shouldn't run a stock p28 on a gsr motor...
Are you throwing any codes ?
Check your malfunction indication codes if you are throwing any & get back to us.
If you have a fast idle thermo valve, rebuild it...
Old Jul 7, 2009 | 12:08 PM
EFbomb's Avatar
lol @ wonky
I'd check for vacuum leaks too, the GSR intake hides vacuum ports and lines
keep_up
Jul 1, 2009 01:52 PM
schwing27
21
Mar 17, 2009 08:49 AM
Chris N
Dec 4, 2003 09:40 AM
