CTR s300 base map
Old May 27, 2009 | 06:12 AM
EJ1B18c's Avatar
Default CTR s300 base map
Hi, my friend droped a valve on his previous motor b16a civic (rally car). So he bought a CTR motor b16b with stock everything except header and intake. I need to put a map on this motor before the weekend. On the s300 preloaded base maps there is a ITR map would this be ok to use? His previous map was tuned for Skunk Pro2's with 11:1 Cr so that is not usable. Rally is comming up this weekend and dont have time to go to tuner. what would you suggest. will anything from the preloaded base maps suffice?
Old May 27, 2009 | 09:33 AM
redlinetuning's Avatar
Default Re: CTR s300 base map
Yes, ITR base map would be closest.
Old May 27, 2009 | 09:42 AM
EJ1B18c's Avatar
do you have s300? can you verify for me that the ''ITR STOCK'' map is from a b18c DC2 and not a k20 DC5.
Old May 27, 2009 | 09:47 AM
K20 DC5 will not run on S300, it requires K-Pro. I was using a S300 Boosted base map to start the car and drive to the tuner.
Old May 27, 2009 | 09:56 AM
EJ1B18c's Avatar
so this one will be ok
File Type: doc
Old May 27, 2009 | 09:58 AM
can't open your file, says can't be found. What are you attaching in the .doc file? Screen shot?
Old May 27, 2009 | 10:03 AM
EJ1B18c's Avatar
yea its a screen shot of the preloaded map called itr stock on s300'
sorry about that
Old May 27, 2009 | 10:08 AM
I don't have SManager loaded at work so I can't open the file to tell you, but that should be the one. I didn't have problems starting with the other basemap.
Old May 27, 2009 | 10:24 AM
EJ1B18c's Avatar
thanks for your input
Old May 27, 2009 | 10:03 PM
turbociv910's Avatar
i have a tuned map with S200 for my stock CTR engine with intake, header, exhaust.
dont know if thats any help
Old May 28, 2009 | 04:32 AM
EJ1B18c's Avatar
i dont know it it possible to e mail it. and will it load up/ convert to s300 anybody? motor will be in the car in approx 5 hrs from now. thanks
Old May 28, 2009 | 10:04 AM
EK9 CTR's Avatar
The ITR map will be quite fine... I've used it to start my stock B16B motor.. The ITR map is for the USDM ITRs if my memory serve me correctly.. Just monitor your A/F ratio with a wideband gauge to make sure everything is fine...
Old May 28, 2009 | 02:31 PM
EJ1B18c's Avatar
ok motor is in. almost finished running it in. I loaded the ITR map and set the timing synchronised the dizzy with the ecu to 16degrees before TDC then calibrated TPS readings.The car accelarates ok to the redline. its a bit slughish down low in the rpm and the vtec engagement point is very agressive. Im trying to get this car put on a dyno in the morning. The car accelerates to 8000rpm with no smoke exiting the rear but when the throttle is let off from high rpm. Its throws out a puff or black/white smoke. If i cant get on dyno ill have to take my aem uego off my own car and datalog.
Old May 29, 2009 | 03:50 AM
EJ1B18c's Avatar
ok put the car on dyno dynamics this morning. the afr is 12 (+-.7). The is down a little on power a stock CTR on this dyno puts down 163 flywheel hp. There has been up to 15 CTR's on this road and they all read around 163Fhp. this car put down 148. It was not tuned on this occasion. But the lack of power is more than likely because of the ignition timing on the USDM ITR map. Anyways car will be rallied this weekend. Then the pro2 will be going in monday,(waiting on valve springs) and off for a tune. thanks
jjmose03
Engine Management and Tuning
Jul 25, 2013 10:51 PM
Type rawr
Jan 9, 2011 02:54 PM
champwhiteEG6
Jul 10, 2009 07:52 AM
Bbasso
Jan 25, 2005 06:09 PM
rice4life
12
Jan 5, 2005 05:27 PM
