s300 boost problem or mac valve
Old Jul 12, 2009 | 01:32 PM
legomytego's Avatar
Default s300 boost problem or mac valve
so i am unable to build more then the wastegate spring thats 7 psi i am to the point to were i just wanna run a big wastgate spring the mac valve has one wire to 12 volt and the other to the ecu i have grounded the ecu wire to test the solenoid and it clicked so i no it works is there anything else i can do to test it ? or s300 thanks guys.
Old Jul 14, 2009 | 08:50 AM
pgpbubble's Avatar
Default Re: s300 boost problem or mac valve
Stupid question, But does your ECU have the PWM components installed?
Old Jul 14, 2009 | 08:11 PM
mtber's Avatar
+2
Old Jul 15, 2009 | 02:58 AM
legomytego's Avatar
yea they are installed lol i no you guys had to ask ive had the boost going thru my ecu for over a year now it just started to mess up the other day i am going to recheck over my wiring again but after that i dont have any other ideas.
Old Jul 15, 2009 | 07:37 AM
mtber's Avatar
Perhaps one of your variables in your settings is not being met to enable the pwm output... ?
Old Jul 15, 2009 | 08:56 AM
legomytego's Avatar
any examples ? car runs fine its just only on 7 psi the solenoid set to come on at 1 psi ive also tried other numbers like 4 psi ive switched it from a norm open to norm closed nothing it will only make wastgate ill look over the map once again and report back thanks for the help guys.
Old Jul 15, 2009 | 06:28 PM
mtber's Avatar
So the pwm output has been working for a long time & now it doesn't ?
Are you using a fixed duty output? If so, what percentage ?
Old Jul 16, 2009 | 02:39 AM
legomytego's Avatar
55% just got tuned last friday i turned it down to 50% tho cause i was hitting boost cut .
Old Jul 16, 2009 | 05:39 AM
mtber's Avatar
Turn it up to 60% and see if it does anything...
Old Jul 16, 2009 | 07:24 AM
pgpbubble's Avatar
Or post your bin file for one of us to check it over.
I recall someone having a similar problem like this after the car sat for a little while and realized his wiring got messed up when he was playing with other things.
Old Jul 16, 2009 | 04:54 PM
sander's Avatar
2.7(p/t)
Back up.
There are two wires on the MAC valve, one is 12V switched power with key on, the other should have less than 2 ohms to D14.
If these two things are correct, then check resistance across the two wires of the valve itself and make sure there is continuity and it is not an open circuit condition.
If this is also right, then you may check the PWM signal coming out of D14 to see if the ECU is actually providing the PWM frequency / signature.
If that is right, then you need to check your wastegate for a stuck valve, torn diaphram, or broken control line (top wastegate line).
SiRCiviC94
May 30, 2016 03:44 AM
justYncredible
Jul 5, 2012 12:17 PM
EARLdaSQUIRREL
Engine Management and Tuning
19
Apr 21, 2009 07:15 PM
B18EG6
May 16, 2008 08:02 PM
lsracer27
May 29, 2004 08:56 PM
