obd1 p30
Old Jun 4, 2009 | 06:46 PM
tallkan's Avatar
Default obd1 p30
any one know what slot R135 is for on the ecu board its burnt and im wondering if its related to the idle probs ive been having wit my car
Old Jun 4, 2009 | 08:31 PM
mtber's Avatar
Default Re: obd1 p30
Your intake air temperature sensor is probably fried... Check it & make sure you have the correct plug plugged into it.
Also, resolve any codes you are throwing (iacv)
Old Jun 6, 2009 | 12:34 PM
tallkan's Avatar
the only thing im not throwing any codes
Old Jun 6, 2009 | 05:17 PM
mtber's Avatar
What kind of idle problems are you having ?
Is your ecu chipped ?
Give us a run down of your engine setup.
Old Jun 7, 2009 | 09:10 AM
tallkan's Avatar
my sig has my set up. im on chrome. im having the stupid idle like my iacv is bad but ive changed it like 4times over the last day and they all do the same thing so im wondering it its that resistor thats burnt
Old Jun 7, 2009 | 10:53 AM
mtber's Avatar
Do you have a fast idle thermo valve on the bottom of your throttle body ?
If so, rebuild it.
Old Jun 7, 2009 | 10:56 AM
tallkan's Avatar
If so, rebuild it.
i wish it was that dammm easy. that was the first thing i did. i even took it if and blocked of the bottom of the throttle body still did the same thing
Old Jun 7, 2009 | 11:03 AM
mtber's Avatar
im on chrome.
Have the car tuned. It is likely your issue.
I personally would run Hondata, eCtune, Neptune.
Old Jun 7, 2009 | 11:07 AM
tallkan's Avatar
it is tuned i got it done in long beach like 3 months ago. ive been thinkin about goin over to hondata s300 but money is tight these days
Old Jun 7, 2009 | 11:08 AM
tallkan's Avatar
its weird tho it just started acting stupid out of kno were.
Old Jun 7, 2009 | 11:28 AM
mtber's Avatar
Make sure your evap purge solenoid is unplugged.
Also, play with your idle set screw on the top of your throttle body. Try and target 750-850 rpms.
Old Jun 7, 2009 | 11:31 AM
tallkan's Avatar
thankz for all the input ive tried everthing you listed allready b4 i hit H-T. i just wanted to see if anyone knew anything else i could prolly try.
Old Jun 7, 2009 | 11:48 AM
mtber's Avatar
I wish you were local I am sure I could resolve the issue in 2 minutes in person :-)
DAman9
Aug 5, 2013 07:17 PM
Luchini
Apr 6, 2010 05:12 PM
ev0luti0n
Sep 27, 2005 07:42 AM
BeerBaron105
Jun 7, 2005 02:22 AM
89_crx
Apr 18, 2005 06:26 PM
