help with re-swap wiring
Old May 15, 2009 | 09:28 AM
cousin_ed's Avatar
Default help with re-swap wiring
hey fellas. i bought a 93 eh2 hatch shell that someone had swapped in an h22
the engine isnt in the car but the passenger side transmission mount has been cut off and a hole has been cut into the floor for a cable shifter.
anyway, i have a b18a1 block im building to put back in this beast. the ecu in my shell is also gone.
here is the problem:
im gonna have to identify what obd this vehicles ecu is. it has 3 gray plugs.
im not sure if it was changed for the h22. also, the car was non-vtec so there is an extra vtec wire ran from the ecu plugs.
is the obd the same for the shell, or could it have been changed for the h22?
Old May 15, 2009 | 09:56 AM
rip94delsol's Avatar
Default Re: help with re-swap wiring
Hopefully they used a conversion harness if they needed but your harness should be OBD-1 which is what you want to have in the car. OBD-1 came stock in that vehicle.
that chould be the vtec wire and hopefully the preswitch aswell.
Old May 16, 2009 | 05:45 AM
cousin_ed's Avatar
ok thanks. well now i have a b series vtec engine harness. can i remove my vtec wire from the car and use the one on the engine harness?
harvster87
Jul 11, 2009 06:22 PM
JDM3STAGEVTEC
Sep 27, 2008 05:19 PM
JSPECEX
May 18, 2005 09:11 PM
delviacv2
May 10, 2004 02:02 PM
st0nedstoopid
Jun 30, 2003 10:58 AM
