B20b Base map?
Old May 29, 2009 | 11:53 AM
ser13's Avatar
Default B20b Base map?
I was wondering is it worth getting a b20 base map for a b20b or would a ls ecu be the same?. I got the b20b with p8r head i think 9.2 compression with basic bolt ons converted to obd1. If it is any one knows any one with a good b20 base map. Thank you
Old May 29, 2009 | 12:59 PM
mtber's Avatar
Default Re: B20b Base map?
The b20 engine uses a different fuel/ignition map then the b18a/b engine.
It would be ideal to run a chipped obd1 ecu mapped for your b20 motor.
Old May 29, 2009 | 03:03 PM
ser13's Avatar
Okay thanks
Old May 29, 2009 | 05:31 PM
ivan93egreppin210's Avatar
im running a stock obd1 p75 (LS) right now on my b20z2 non vtec. my fuel is set to 45 psi. it runs but im sure it would run better with a chipped ecu.
JDMswagSerf
Feb 7, 2016 02:50 PM
efkilla
Aug 28, 2014 10:09 AM
rexracer626
Jun 24, 2010 06:28 AM
ser13
Engine Management and Tuning
Oct 28, 2009 07:11 PM
Hybridize
Jun 5, 2009 07:47 PM
