Which ECU do i need?
Old Jun 19, 2009 | 07:08 PM
jdmborn's Avatar
Default Which ECU do i need?
i am putting a b18b1 that i am building into my 97 civic ex with the d16y8. what is the best ecu i need for the swap, i may get a performance ecu so any help would be great.
Old Jun 19, 2009 | 09:50 PM
mtber's Avatar
Default Re: Which ECU do i need?
The best solution would be an obd2a to obd1 jumper harness with a chipped obd1 ecu for your engine setup.
You can also use an obd2 stock p75 ecu if you desire to retain the stock ecu.
Old Jun 20, 2009 | 08:15 AM
Relic1's Avatar
Originally Posted by mtber
The best solution would be an obd2a to obd1 jumper harness with a chipped (and tuned) obd1 ecu for your engine setup.
You can also use an obd2(a) stock p75 ecu if you desire to retain the stock ecu.
agreed with a small change.
Also, there is no such thing as a "performance" ECU. IMO that's just Ebay marketing crap at it's finest.
GT500FTW
Nov 5, 2012 09:57 AM
dwarfsinhondas
Engine Management and Tuning
Apr 7, 2008 11:47 PM
kanSiR
Nov 8, 2007 08:02 AM
RACEPAK
Jun 7, 2005 07:42 PM
mrx
Mar 28, 2005 05:56 AM
