setting up PWM
Old Jul 3, 2009 | 05:32 PM
xander1100's Avatar
Default setting up PWM
not sure if this belongs in tech, FI, or here, but its ecu based so here it goes:
how do i set up a PWM solenoid? havent found any tech articles for it, and i do mean full set up. from whatever part of the turbo it connects to to the solenoid to the ecu. any help (especially diagrams) would be great, thx
Old Jul 3, 2009 | 09:37 PM
locash's Avatar
Default Re: setting up PWM
Which solenoid are you using? If it is the Mac valve, port 1 should go to the boost source and the bottom of the gate, and port 2 goes to the top of the gate, while port 3 is open or has the muffler/filter thing on it. One wire goes to +12v ignition power, the other wire goes to pin A11. That is just the info off the top of my head, sorry, I dont feel like drawing a diagram..
Old Jul 3, 2009 | 09:53 PM
xander1100's Avatar
yeah sorry its the MAC valve from xenocron
great info thx. both wires look the same (either that or im going color blind) so i take it it doesnt matter which one goes where?
Old Jul 4, 2009 | 07:43 AM
mtber's Avatar
There is no continuity....
You can find a plumbing & wiring diagram on http://www.phearable.net/tech
Your ecu must have PWM control components in it to control a11.
Old Jul 4, 2009 | 02:11 PM
xander1100's Avatar
sweet, checked out your website earlier looking for a diagram but i guess i missed it. thanks
#3 says its an atmospheric filter...do i hook anything up to that or do i just leave the space open?
Old Jul 4, 2009 | 05:15 PM
mtber's Avatar
Use a brass cone filter.
Old Jul 5, 2009 | 09:57 PM
xander1100's Avatar
anywhere in particular that sells those?
Projectludatic
May 25, 2010 12:29 PM
TB123
Engine Management and Tuning
15
Jun 26, 2008 01:24 PM
Sketch_hs
Aug 19, 2004 08:44 AM
HT Chaplain
Jun 8, 2004 03:41 AM
