crome pro quick question
Old Jun 14, 2009 | 12:12 PM
wrx'n you's Avatar
Default crome pro quick question
quick question for the crome pro users here. how can i convert the lambda readings to AFR readings under the target lambda chart and lambda readings chart? thanks in advance
Old Jun 14, 2009 | 01:42 PM
YFZpilot's Avatar
Default Re: crome pro quick question
File>settings... under the general tab on the bottom right corner you will see a check box: Air/fuel Ration. check the box and you all set.
spoon93
Dec 27, 2007 09:50 PM
b16adx
Nov 21, 2004 08:18 AM
r1racer
Feb 5, 2004 01:39 PM
