Moates Hulog Problem on Crome PRO
Old Jul 11, 2009 | 08:27 PM
phoshyzzle's Avatar
Default Moates Hulog Problem on Crome PRO
I recently purchased the Dyno Tuning Package from xenocron.com with a Crome PRO license. It came with the ostrich 2.0, the moates extreme hulog, the chip burner, annd ofcourse the crome PRO license. i installed everything correctly, following the moates guide off xenocron. My laptop connects to the ostrich just fine but when i click live tuning to connect to the hulog, it says fail to connect to ecu. i tried connecting it to different usb ports and the same thing happens. We plugged the hulog in the way the plugs matched into the header (orange,red,pink,black) We also tried plugging in the hulog plug that goes into the header the opposite way (black,pink,red,orange) What could it be?
yes, i searched. couldnt find a thing.
its 12 in the morning, i cant find a thing. My head hurts and i need answers.
please.
Old Jul 11, 2009 | 09:31 PM
Bangher4$'s Avatar
Default Re: Moates Hulog Problem on Crome PRO
j12 is cut out?
check the com ports to match.
Old Jul 11, 2009 | 09:45 PM
B16Drag's Avatar
I found this page to be the most helpful for sorting it out. I hope it helps
http://forum.pgmfi.org/viewtopic.php?t=6116
ok ill give you guys step by step on what i did to get my datalogging to work...
setup/hardware im using...
USDM P30 ecu (Chipped of course w/ zif) J12 REMOVED
Moates Burner -usb cable (1.0.2154.0 port driver) be sure to update
Moates Ostrich -usb cable (1.0.2154.0 port driver) be sure to update
Moates Hulog -usb cable
Plx R-500 wideband
Ok thats the hardware im using you can find the moates stuff at http://www.moates.net very good hardware..
Ok now the procedure...first i set up my ports...
-Moates Burner port 4
-Moates Ostrich port 3
-Moates Hulog port 4 (i dont use the burner at the same time when i rtp or dl so its ok to assign same ports..)
Then i:
-open Crome
-file>new>P30 JDM (203) rom
-Plugins>Enhancements>Remove Check Sum
-Plugins>Enhancements>Quick Datalogger + RTP
-File>Save as>"whatever you want"
Now:
Using whatever burner you have...burn a chip with that bin file you saved..install the chip into your ecu (having a zif will make things 10 times easier to remove chips in and out)...turn on the car be sure it runs with no cel..then turn it off
Now: (if you dont have a romulator skip this)
Plug in your moates ostrich if you have one or whatever romulator you have...but do not plug it into the ecu, only ur laptop at this time...besdies your testing it for now..and plus u have the other chip installed in it
Then:
Plug in your datalogging hardware from your ecu to your computer, in my case i have a Hulog...the hulog if you visit the website is a small black box that connects the tx rx and ground wire from your ecu to the black box and from there a usb cable plugs into your computer..(the tx and rx lines are crossed on purpose on the hulog, so dont chang it if you purchased one..and make sure they are crossed) For anyone else using other means to connect...im not sure how the are connected..
Ok getting closer:
If you have a wideband, you should have already connected it...on the PLx R-500 theres a white wire for output...connect that to the o2 signal off the ecu wire harness ( i tapped into it using a splicer and male) and of course ground and power your wideband...
Open Crome:
-Open the same bin you burned
-File>settings>Real Time programming tab: (Skip this if you have no romulator)
-Select your Hardware type (Ostrich)
-Port setting (Com 3)
-Baud (115200)
-Data Bits 8
-Parity (None)
-Stop bits (1)
Leave the connection settings alone
TEST CONNECTION! it should say connected successfully, if not be sure your not connected to the ecu..it should load up without any connection to the ecu socket...
Moving onto the Tunner Com Tab:
-Serial Protocol (PGMFI OBD1)
-Port (Com 4)
-Baud (38400)
-Data Bits 8
-Parity (None)
-Stop bits (1)
Connection Settings leave alone
TEST CONNECTION!
-now for me while the car is off says not connected to ecu, but for some it may connect...you have to turn the car on in order for it to work...dont do it just yet..complete the rest of the settings..
-if you get a 'Bad response recieved. Check your settings' then you have the wrong port setting go back and check the right port setting.
Tunning Logging Tab:
-select the wideband you are using, if not select stock narrow-band
-dont worry about the lamda offset yet..you have to compare when you datalog with crome and the actual reading off ur wideband..
NOW push OK, should close you out of the settings window..
-Start the car, your burned chip should be in..
-Now click on the toggle tuner toolbar..its the Black RPM icon or ctrl+T
-click on live tunning at the bottom
It should now have you connected to the ecu and a box should open to the right with all the parameters mph, afr, rpm etc..
Now for ostrich: (Still should not be connected to ecu yet)
-Click the toggle rtp tool bar or ctrl+R
-On the RTP tool bar which should be above your fuel/igntion maps click 'PUT'
-Click 'Verify'..now ur ostrich is ready for rtp
Now turn off your car:
-Remove the burned chip
-Put the ostrich eprom into the ecu socket, be sure if using a zif you latch it down completely!
-turn the car back on..should run
-click live tunning agin on the bottom and now you should be all connected!
I have found for the ostrich that somtimes it wont verify or update the tables while connected to the ecu..what i have done that works is to..shut the car off...take the EPROM OUT and then load, update and verify...it usually does the trick then plug it back into the ecu...but for most of the time it works great..it just happens once in a while..also if that doesnt work...do all the above but exit crome, be sure to save if you changed anything..and reopen crome and upload or 'put' the file back and then verify..it should work and then plug it back into the ecu and you should be good to go!
Your are now ready to datalog and RTP Hopeuflly! :D
Note this is my personal experience on how to connect! so it may or may not work for you but im hoping it will!
So try it out!
Old Jul 11, 2009 | 11:16 PM
phoshyzzle's Avatar
Thanks alot for the help. I'll try first thing in the morning. I did not cut j12 because I'm using a jdm ecu so I was told to cut j4.
Old Jul 12, 2009 | 12:59 PM
phoshyzzle's Avatar
i tried these steps, and i still cannot connect to the ecu with the hulog.
Old Jul 12, 2009 | 01:33 PM
Bangher4$'s Avatar
Do you have the driver installed for the usb cable?
Old Jul 12, 2009 | 04:44 PM
phoshyzzle's Avatar
where can i download the driver to be sure.
Old Jul 12, 2009 | 08:13 PM
bigD's Avatar
http://www.moates.net/product_info.p...products_id=66
Old Jul 12, 2009 | 11:09 PM
phoshyzzle's Avatar
I downloaded the drivers, still nothing
Old Jul 13, 2009 | 05:19 PM
phoshyzzle's Avatar
anyone? is it a possibility that i cant datalog if the 74HC373 chip is fried? wouldnt the ecu not work at all if the 74HC373 was fried?
Old Jul 13, 2009 | 08:41 PM
DOHCtorTHRUST's Avatar
cut the j12. i had the same problem for the longest and finally went over everything only to realize that the j12 was never cut on that ecu. once cut, connection was made, map tracing, datalogging works.
Old Jul 14, 2009 | 08:02 AM
phoshyzzle's Avatar
if you read what i stated above, i am using a jdm ecu. i have to cut j4 instead of cutting j12. i already did this, and still no datalogging.
Old Jul 14, 2009 | 08:50 AM
pgpbubble's Avatar
Com ports correct?
Old Jul 14, 2009 | 10:04 AM
phoshyzzle's Avatar
yes.
Old Jul 14, 2009 | 01:29 PM
sanimalp's Avatar
$cat /dev/urandom
You have to check the com port in 3 spots. First, the com port and baud defined on the burned chip in crome. Second, make sure that information matches in whatever you are datalogging in, crome or freelog or ecucontrol, whatever. Third, make sure the com port setting for the usb-serial adapter are set to match the com port settings.
second, no you will not be able to datalog if the 74hc latch is messed up. The ecu won't be able to address to the chip socket. you need to replace the 74hc chip if you think it is fried.
Old Jul 14, 2009 | 11:19 PM
phoshyzzle's Avatar
if the chip is fried, wouldnt my car go into limp mode? like i said, when i burn a map i find online on a chip, and insert the chip in my ecu, the car runs fine.
Old Jul 15, 2009 | 07:47 AM
sanimalp's Avatar
$cat /dev/urandom
no, it will just revert to using the stock map that doesn't have the datalogging routine.
You can test it however, by going in to crome and setting your rev limit to 2k rpm. Then, burn the chip and insert it, and try to rev above 2k rpm. If you cant, it means it is reading from the chip.
Old Jul 15, 2009 | 08:51 AM
phoshyzzle's Avatar
well i set my launch control to 4k, and launch control worked.
Old Jul 15, 2009 | 10:57 AM
sanimalp's Avatar
$cat /dev/urandom
Then it is reading from the chip.. Is the header soldered in wrong? Pin 1 being in the #2 slot for instance? If your datalogging header is soldered in wrong, it doesn't matter what direction you connect the cable in. Use this for reference.. http://www.moates.net/documentation....entation_id=25
Old Jul 15, 2009 | 11:52 AM
phoshyzzle's Avatar
im sure thats the problem, but heres the thing, im using a jdm ecu, when i was soldering in my header i looked at the usdm ecu looking at how it was soldered in (i.e. the clip was facing the numbers on CN2) maybe it was supposed to go the other way since its a jdm ecu? thanks alot for the help.
Old Jul 15, 2009 | 02:08 PM
sanimalp's Avatar
$cat /dev/urandom
here is another good reference just to cross check what you are doing.
http://www.scribd.com/doc/12609689/T...ith-CROME-v106
SpoonREVS
Dec 11, 2012 09:20 AM
Barknuts88
Sep 22, 2008 08:36 PM
Thateguhate
Aug 16, 2008 09:24 PM
Rocket
43
Jun 2, 2008 09:14 PM
rhd
Nov 29, 2004 08:01 AM
