Data logging for break up after 12psi >>
Old Jul 18, 2009 | 08:50 AM
platinum00's Avatar
Default Data logging for break up after 12psi >>
Have and S300. Typically run 18psi on pump. Has been running for a couple years that way. Started breaking up after 12-13psi the other day. Replaced the plugs, same issue.
What can I log or check to diagnose?
-platinum
Old Jul 18, 2009 | 03:49 PM
HRTuning's Avatar
Default Re: Data logging for break up after 12psi >>
Check that you properly gapped the new plugs.
Old Jul 18, 2009 | 05:31 PM
postman's Avatar
map sensor maybe, like stated check the plugs for proper gap and same brand as previous usage
Old Jul 18, 2009 | 06:22 PM
mtber's Avatar
1. Make sure your air fuel ratios are on par.
2. Check plug gap as mentioned before.
3. Consider taking the vehicle back to your tuner for inspection, a good tuner can diagnose an issue such as yours in less then a few minutes....
Old Jul 19, 2009 | 05:13 AM
platinum00's Avatar
A/F looks solid. 11ish at wot. Idle is spot on 14.7.
New plugs are the same brand and heat range gaped at .028
Nothing I can log on the S300 to determine the issue? I am going to check cap and rotor today.
-platinum
Old Jul 19, 2009 | 09:09 AM
HRTuning's Avatar
No, if it was fine before and is now suddenly doing this, unless it's a bad sensor logging will not help you.
Try gapping lower, honestly.
Old Jul 20, 2009 | 05:26 AM
sander's Avatar
2.7(p/t)
Try .020" see if the problem lessens.
Old Jul 20, 2009 | 08:04 AM
HRTuning's Avatar
I was going to suggest .024
Old Jul 21, 2009 | 06:14 PM
jdm602's Avatar
also what plugs you use are something to consider too. my bkr7e's started breaking up one night at the track and that was on 11 lbs. i had them gapped to 28. now i gap mine at 20. problem fixed.
Old Aug 1, 2009 | 11:21 AM
platinum00's Avatar
cap, rotor and plugs replaced. All is well.
thanks guys.
corys_ej8
Sep 2, 2011 06:12 PM
JDM_EK4_Coupe
10
Apr 19, 2007 08:23 PM
ZWK
Mar 27, 2007 05:50 AM
0260MOTORSPORTS
Dec 23, 2006 02:59 PM
sporkcrx
Jul 3, 2004 07:59 PM
