ecu problem please help
Old Jun 3, 2009 | 07:30 PM
dsmslyr55's Avatar
Icon2 ecu problem please help
hey guys i have a ecu i got chipped from phearable.net its a very nice ecu only problem im having is my car is a 2000 si with bassic boltons and with my ecu it runs perfect but when i plug in there ecu it runs rich and sometimes bogs he said do to the fact that i do have a obd2 motor setup to unplug the evap purgue soliniod will that mess the car up at all? and do u guys have any suggestions at all on wat i should be lookn at? thanks alot guys
Old Jun 4, 2009 | 05:53 PM
FaceTuned's Avatar
Default Re: ecu problem please help
what brand jumper harness
Old Jun 4, 2009 | 05:59 PM
93turbo16's Avatar
You will need to unplug the evap purge control solenoid because the outputs are inverted between OBD1 and OBD2 ECUs.
Just unplug the electrical connection. It will not hurt a single thing.
Old Jun 4, 2009 | 08:32 PM
mtber's Avatar
As described via email, try unplugging the evap purge solenoid. If you are still having issues after contact us.
jamesfawcett
Apr 12, 2010 08:44 AM
Hatchorama
Dec 27, 2006 07:06 PM
husller4life
Dec 15, 2005 10:42 PM
Jbunn2001
Jul 26, 2005 07:31 PM
