Moates Flash N Burn + Chrome
Old Jun 14, 2009 | 04:27 PM
92turbob16's Avatar
Default Moates Flash N Burn + Chrome
I have a socketed ECU and am using Flash N Burn to read my chip now so that I can open it up in Chrome and edit some stuff. When I read chip to save it then open in Chrome, I get an error saying "Can't load file." Am I doing something wrong? What should be done correctly?
Old Jun 14, 2009 | 04:30 PM
xenocron's Avatar
Default Re: Moates Flash N Burn + Chrome
Maybe your program wasnt made in Crome originally...
92turbob16's Avatar
I know it was for a fact though..
Old Jun 14, 2009 | 04:47 PM
xenocron's Avatar
Make sure you have the OFFSETS set correctly...
Chip Start - 008000
Chip End - 00FFFF
Buffer Start - 000000
Buffer End - 007FFF
And of course make sure you have the correct chip selected...
Old Jun 14, 2009 | 05:14 PM
92turbob16's Avatar
Those were correct.. still didn't work..
Old Jun 15, 2009 | 11:47 AM
RyanA's Avatar
Well, if you have a blank chip, here is what I'd do:
1. Put chip in your burner.
2. Click erase chip.
3. Click blank check. Make sure chip is blank.
4. Click load file to buffer and load a file from Crome.
5. Click write buffer to chip.
6. Click verify. Make sure that it says that it was verified.
7. Now, click read chip.
8. Click save buffer to file. Name the file and save.
9. Try to open that file in Crome. If it opens no problem, you have an issue with the read of that chip and it probably IS NOT Crome or it's corrupted.
Old Jun 15, 2009 | 01:14 PM
ddd4114's Avatar
You probably have an outdated version of Crome. I get the same error when I try using Crome 1.2 to read a ROM that was made with Crome 1.5.
Old Jun 15, 2009 | 04:50 PM
xtremhealer's Avatar
New User
guys is there any way to plug in the stock ecu for civic 1999 and tune
Old Jun 15, 2009 | 05:51 PM
RyanA's Avatar
Oh hai there! Click "New Topic" and try again....
Old Jun 16, 2009 | 08:16 AM
92turbob16's Avatar
I got everything to work finally.. I'm running into another little annoyance though. Randomly driving around town, my AFRs will shoot to 10.0 and sometimes shut the car off when I'm decelerating to a red light/stop sign. It's not every time I drive the car though. Sometimes it can do it 1-2 times in 20 minutes of driving, sometimes it won't happen. Has anybody encountered this problem before or have any clue as to what it could be? I'm stumped as well as everybody I know that is into Hondas.
Honda4life777
Engine Management and Tuning
Jul 11, 2009 09:39 PM
Powered By Garrett
11
Jul 4, 2008 08:44 AM
crashzerothree
Aug 21, 2007 07:41 AM
seen4ever
Aug 4, 2006 12:06 PM
the.hamburglar
Mar 20, 2006 03:28 PM
