e85 tuning questions
Old Jun 1, 2009 | 04:51 PM
c5R's Avatar
c5R
Default e85 tuning questions
well every one im running a b18b on 9lbs with precision sc32 im new to the e85 game and would like to ask some questions im not new to tuning at all i made 224hp/209tq on my d16y7 at 9lbs on 91pump gas and ran this thing for 2 years flawlessly also im using a AEM for tuning and am fairly good with it.
how much timing would you recomend i run up to
and what kind of lambda #s should i be looking for with e85
Old Jun 1, 2009 | 05:31 PM
likwidchz's Avatar
Default Re: e85 tuning questions
well with E85 I have been told you need to run a global percentage increase of fuel on your entire map just by having E85.
As for the specific AF ratio using google...
I came up with this "E85 requires 39% more fuel to reach stoich"
as for the Stoich value on your AF meter your looking for 9.8:1
so under boost youl be needing bigger injectors..
Old Jun 2, 2009 | 08:46 AM
c5R's Avatar
c5R
nope my injectors are plenty big 150lb/hr ford motorsports. thanks though i had a hard enuff time geting it to idle with these lol b ut it does flawlessly at 900rpm nex is geting my tune correct im about to switch back to gas and give up
Old Jun 12, 2009 | 08:56 PM
jspeccrx91's Avatar
read my sig good info in there
Old Jun 13, 2009 | 05:29 AM
Turbogixxer's Avatar
It is NOT a global change. E85 percent change is dependant on the injectors and the BSFC of the engine.
Jdc5
Nov 20, 2008 12:12 AM
EZ$$EF
Oct 8, 2008 06:39 AM
Rotten Egg
Engine Management and Tuning
Aug 1, 2008 10:14 PM
purpleh22
Jul 11, 2006 08:31 PM
NyQuiL
Jul 9, 2003 08:52 PM
