Is it possible swap B18 LS engine automatic?
Old Jul 1, 2009 | 05:18 PM
YTYPER's Avatar
Default Is it possible swap B18 LS engine automatic?
Just wondering is it possible to swap a B18 LS engine with automatic transmission into my 94 EG automatic? How hard will it be and any chassis modification need?
Thanks for the help
Old Jul 1, 2009 | 10:05 PM
tazeat's Avatar
Default Re: Is it possible swap B18 LS engine automatic?
Shouldn't be any chassis modification, but the engine management comes in to play... Is the LS OBD 1? You may get away using the stock B18 LS ECU. As far as tuning or any aftermarket a/f adjustment items you won't find much if any for automatics...
Old Jul 2, 2009 | 05:10 AM
YTYPER's Avatar
Someone told me that the tranny side mount is different than stock SOHC tranny, that made me confused. Becasue it is just direct swap on Maunal, so I expect it should be the same as automatic.
Thanks
Old Jul 2, 2009 | 05:15 AM
93turbo16's Avatar
The ecu stuff actually isn't that hard. You will have to wire in the auto LS tranny computer and just use the stock auto LS ecu for the engine.
The shop did a full auto swap into an auto del sol a few years back. The passenger side frame rail needed some persuasion but other than that I believe it fit ok.
Old Jul 2, 2009 | 07:00 AM
Blown90hatcH's Avatar
I make the ecu harness to install the auto OBD1 integra setup into the OBD1 civic chassis if you are interested.
Old Jul 3, 2009 | 07:35 PM
YTYPER's Avatar
Do u know how hard it will be ?
bleedblue94
Aug 18, 2007 07:15 AM
marcodarko
Jul 2, 2007 12:18 PM
nitelifegod
Jan 30, 2005 01:52 AM
Smoking LS
Jan 26, 2004 04:35 PM
