converting an auto P28 to manual
Old Jun 18, 2009 | 11:39 AM
ThisIsLX's Avatar
Default converting an auto P28 to manual
hey i cant afford a hondata or anything like that and i've been told i can just open the ecu and add a resistor to convert it from auto to manual. is this true and how do i do it if so... please give me good news
Old Jun 18, 2009 | 06:40 PM
pb16b's Avatar
Default Re: converting an auto P28 to manual
other way around. remove rp17 and you're done.
Old Jun 19, 2009 | 08:00 AM
Relic1's Avatar
^^^^ depending on the version of board, leaving the resistor in RP18 may cause issues. (certain scenarios may cause the ECU to attempt to pull up that line, the resistor allows it to pull up slightly and will cause problems.)
Adding a jumper to RP18 fixes this.
remove RP17, jumper RP18.
the jumper can be the leg from a resistor, so it costs nothing. and you're sure you will never have any problems.
Old Jun 19, 2009 | 05:34 PM
pb16b's Avatar
good call. yes, while you're at it, jump rp18 as well.
thizboii
Feb 8, 2008 02:30 PM
White_EK49
Jan 14, 2007 12:25 PM
THC07
Jan 9, 2006 04:05 PM
cjames235
May 1, 2003 07:23 AM
civiksi
Jun 7, 2002 05:41 PM
