D16z6 injectors
Old Jun 14, 2012 | 07:25 PM
martinoq92's Avatar
Default D16z6 injectors
What injectors will bolt up to a d16z6. I saw somewhere that a h22 will bolt up but is this true? If not what will thanks for yr time
Old Jun 15, 2012 | 12:08 PM
GhostAccord's Avatar
Default Re: D16z6 injectors
Are you using a fuel controller of some kind? Just dropping in a set of 310/290cc H22 injectors on a stock ECU won't work. Also the early H22 injectors (310cc) require a resistor box.
Old Jun 15, 2012 | 08:29 PM
mtber's Avatar
There is no reason to upgrade your d16z6 injectors unless you are maxing out your current injectors. Stock injectors are fine for most applications under 200 hp.
Old Jun 17, 2012 | 08:24 PM
martinoq92's Avatar
i saw that the 97 prelude had 265cc peak and hold. and no fuel controller yet. untill i go turbo. wont be for awhile because jus wanna be n/a for now.
BxBomber712
Feb 4, 2010 04:45 PM
92ehatch
Feb 8, 2007 04:47 AM
whitehf
Aug 26, 2005 03:40 AM
philafelman
May 11, 2004 04:22 PM
creechrr
May 15, 2003 09:12 PM
