Help bad injector driver....
Old Jul 15, 2012 | 11:16 AM
CrxB16a2's Avatar
Default Help bad injector driver....
Hello all, Have a obd-1 vtec ecu that is getting a solid ground. (not a pulse) from pin a2 (to inj 4) have a code 16, and 14. Is their any information anyone can lead me to how to repair or replace the injector driver? Or any other parts in the ecu causing this problem? Thanks guys. I used to the search button and couldnt find crap. Hopfully a honda tech can help me out..
Old Jul 16, 2012 | 06:34 PM
HiProfile's Avatar
Default Re: Help bad injector driver....
Its been a while, but it's components QM1-3 that are the actual transistors. It could also be a bad diode, but unlikely. Trace the pin back to one of those 3 black components, replace with one from another ecu, and it should work. Otherwise it's further back in the circuit, meaning the processing unit - which is more work than it's worth. You won't be able to find these parts new FYI.
chintanwall
Honda Civic (2001 - 2005)
Sep 17, 2016 01:06 AM
TURBO DC2
Aug 19, 2010 05:36 PM
TURBO DC2
Jun 3, 2005 11:10 AM
btrim23
Feb 9, 2005 08:51 AM
daidilus
Jun 10, 2004 11:54 AM
