help with tune
Old Jun 14, 2012 | 02:52 AM
crxx44's Avatar
Default help with tune
Hi l want help What tools do I need to work with honda
Old Jun 14, 2012 | 08:48 AM
Spunkster's Avatar
Default Re: help with tune
metric
Old Jun 14, 2012 | 11:05 AM
crxx44's Avatar
l Thinking to take innovat Lm1 wideband and Ostrich 2.0 and what need to tune my obd1
Old Jun 14, 2012 | 11:49 AM
Dc4LsTeG's Avatar
EK9
A dyno
Old Jun 14, 2012 | 12:36 PM
EJ8_Man's Avatar
Originally Posted by Spunkster
metric
This was my first thought too, but I refrained from the urge to flame
Old Jun 14, 2012 | 04:44 PM
EF9_TryMe's Avatar
metric
AHHHHHHHH HAAHHAHAH!
Old Jun 14, 2012 | 09:33 PM
BigPoppaD16's Avatar
i curently have a 93 honda civic ex with a D16Z6 motor (first honda, and first project) it has a aftermarket air intake currently added onto it with a bundle of other parts im looking to find an air charge temp. sesonor and the connector/wires for it to install in the air intake but after looking at a dozen or more websites and roaming the junkyards havent come acrossed anything. any help or tips on it greatly appreciated. ive got the engine light on and seems like its idling kinda funny. at times when im sitting at a light the engine just stops like it isnt taking in any air and i have to restart it. at times the engine light does go off but when im stopped and try to accelerate it takes a minute or two to respond and even then is a little sluggish. i have a buddy who has put together a few hondas and works with a shop and says its the air charge temp sensor (secondary air sensor in the air intake) and ive been lookin for it but havent been able to come across it or the wires for it (which i need). any ideas on where to definately get them or any tips would be helpfull
Posted from Honda-tech.com App for Android
Old Jun 14, 2012 | 09:51 PM
raverx3m's Avatar
lol wtf this thread is a NOOB magnet
Old Jun 14, 2012 | 09:55 PM
raverx3m's Avatar
OP first of all what do you know about honda
to me you sound like someone that shouldnt touch the car and just take it to a shop or dyno.
theres already too many noobs destroying good hondas and turning them into garbage and then trying to get rid of them on craigslist
to tune your car yourself first of you need to know what you doin
and if you dont know what tools you need then you DONT know what you doin
you need a wideband
chipped ecu such as (crome, neptune or hondata )
laptop
with crome you also need datalogger and real time programmes like ostrich
a car that has no issues
egr sensor would also help
Old Jun 15, 2012 | 02:09 AM
crxx44's Avatar
what is the best lm1 or lm2
Old Jun 15, 2012 | 02:56 AM
alperx's Avatar
can I find any information about "how to tune ignition using dyno" ?
Old Jun 15, 2012 | 07:33 AM
raverx3m's Avatar
wow
Old Jun 15, 2012 | 12:26 PM
GhostAccord's Avatar
Just when I didn't think H-T could get any worse! Today takes the cake!
Old Jun 15, 2012 | 01:08 PM
boostedgeezer's Avatar
OMG!!!!!!
Old Jun 15, 2012 | 02:28 PM
raverx3m's Avatar
Sorry man but u gotta read more.
Old Jun 15, 2012 | 02:58 PM
alperx's Avatar
No need to make fun of.
I'm not asking for a teacher online.
Someone can 'point' a book or a website, that was what I expected actually.
I adjusted the AFR via wideband on the street on a GSR basemap. The ignition is based on also GSR and retarded 1 degree per psi just to make sure there's no problem. I see there's no problem afer I check the plugs. At least no detonation.
I have a knock sensor on the block and a knock gauge, however I can't trust that for the moment. Headphone style knock listening is needed. My friend has one with its knock sensor, and I'll use it, however, I only use it on the street and it's not easy.
The ecu is P28 with neptune.
That's where I am. There's only one dyno in my city and I want to rent it. However, I need to know more about dyno tuning.
So, is there any good information on using the dyno for tuning ? Just to read ?
Anyway..
Old Jun 15, 2012 | 05:10 PM
raverx3m's Avatar
thats more like it. why not include your last post in the original that way you dont look like a complete noob.
more info you give better we can help
Old Jun 15, 2012 | 05:12 PM
raverx3m's Avatar
i think an EGR would be more help to you than a knock sensor
why not have the tuner dyno tune it first so you can watch what he does, you will have better idea
Old Jun 16, 2012 | 07:21 AM
K20EF8Dx's Avatar
I do believe you mean EGT (Exhaust Gas Temperature) .
Alperx, There are several ways of tuning ignition depending on street, and dyno type. I understand you are familiar with knock ears and reading plugs which is the way of the street tuning.
Coming down to the Dyno it depends on type Inertia or Steady State. I currently use a Inertia dyno which isnt really well for part throttle tuning. I still read plugs on it but wot you can watch the tq curve either go up or down. make a run look at graph, add 2 degrees then overlap. if there is no gain in say 4k rpm then take 2 degrees back out. if you gain at 5k rpm up to 9k add another 2 degrees, rinse repeat.
Steady state is ideal for speed density cars (Map Sensor), it can hold you in a certain cell and you can dial in your part throttle while looking at its tq management controls you can add timing until you see a peak in number then back off slightly. Currently been renting a Dyno Dynamics and the part throttle ignition maps have been solid.
Hope this helps you
Old Jun 16, 2012 | 07:24 AM
raverx3m's Avatar
*cough yep that one. been hangin around d15z1 too much
Old Jun 16, 2012 | 12:12 PM
alperx's Avatar
Thanks K20EF8Dx. This is the kinda info I need. Is there any books on stuff like that ?
Old Jun 16, 2012 | 12:15 PM
K20EF8Dx's Avatar
Ben strader wrote a good book he is the owner of EFI University (www.EFI101.com) there are a few others on amazon. I have read a few but its informative to start off slow and advance yourself and take in criticism from others.
muneebahmed
Honda Fit
Jun 15, 2018 09:31 AM
vdavenp802
Honda Civic (2006 - 2015)
Jan 2, 2015 07:06 AM
hondakid09
Jan 10, 2010 04:54 PM
twounderstand
Honda Civic (2001 - 2005)
Aug 4, 2006 05:02 PM
