Help with Hondata CPR kit.
Old Jun 19, 2012 | 08:40 AM
Super79Dave's Avatar
Default Help with Hondata CPR kit.
I purchased a hondata coil on plug replacement kit.
I have checked and rechecked the wiring and am pretty sure i have it right but i am not getting the it to sync.
Was looking for detailed pics of someone elses to confirm i have wired it correctly.
ECU is p75 hondata s300. CPR is turned on and map is uploaded.
Running civic coils, confirmed no spark.
Ground is good on tstat housing.
Ground to CPR module good, ICM to module good, PWR to module good.
Still no SYNC.
Car is 89 civic dx converted to MPFI running a rywire conversion harness from obd1-obd0 with vtec subharness.
Any assistance greatly appreciated.
Old Jun 19, 2012 | 08:58 AM
mtber's Avatar
Default Re: Help with Hondata CPR kit.
Did you check to make sure your p75 ecu has Q37 in it?
Most Canadian ecus do not.
Without the transistor on Q37 the CPR will not work.
Old Jun 19, 2012 | 02:04 PM
just saw they added this to the instructions today.
Yup ecu is missing q37.
Does anyone know what size transistor is required??? or just contact hondata.
Internet says something about a d1423 transistor, but am unsure if this is correct.
http://www.moates.net/q26-and-q37-d1...pack-of-4.html
My CPR kit was an early version and did not come with the transistor.
I was finishing other projects and am just now trying to make it work.
Old Jun 20, 2012 | 10:54 AM
Hondata is sending me a transistor.
Old Jun 20, 2012 | 11:41 AM
mtber's Avatar
Awesome customer service :-)
HKSone
Aug 14, 2006 12:52 PM
Civic Hybrid
May 29, 2006 02:02 PM
CA18DORI
Dec 23, 2005 05:19 PM
NoVtecLs
Oct 6, 2004 05:54 PM
Brian_92GSR
Nov 15, 2001 01:58 PM
