Autometer AFR Guage help?
Old Jul 20, 2012 | 03:46 PM
TomCurllyFry's Avatar
Default Autometer AFR Guage help?
whats up guys fumb question but im have issues wiring up my guage black ground red power and purple i have connected to the White wire directly on the O2 sensor. the problem imm haveing is as soon as i connect the puplr to o2 iu lose all guage power, but if i disconet just the pule it lights up again? anyone haveing this issue? thanks
Old Jul 20, 2012 | 04:23 PM
GhostAccord's Avatar
Default Re: Autometer AFR Guage help?
Honestly, I'm going to be blunt, Those gauges aren't worth shyte! Sell it for as much as you can. The stock narrow band O2 only has a 0-1v signal.
However if you want to wire it up you would be better off wiring it directly to the PHO2S pin @ the ECU. What model and year car are you hooking this up too?
Bongnak's Avatar
white from the o2 isn't the signal wire( assuming its a four wire; Black, grey, two whites) . what colors are your o2 wires. And why didn't you do research on o2's. If you're using the gauge for anything important you should have bought a wideband instead.
Old Jul 20, 2012 | 04:31 PM
Depends on the chassis, however most Honda O2 sensors I have worked on have
2 black (or BLK/YEL & BLK/WHT)
1 white (or WHT/RED) and
1 green (or GRN/BLK)
And the white (WHT/RED) is usually the O2 output signal. However, it is still better to get the signal from closer to the ECU.
Old Jul 20, 2012 | 04:45 PM
i looked up on it and it said use the white and i belive mine is the came as this 4wire
and its going on a 94 Cx eg hatch
Old Jul 20, 2012 | 04:46 PM
i also have vafc on the car
Old Jul 20, 2012 | 05:04 PM
OK so if you are looking to do any sort of AFR monitoring. Drop the narrow band O2, autometer gauge and get yourself a real wideband O2 sensor and gauge.
Innovate Motorsports makes very reliable products for a good price.
Old Jul 20, 2012 | 05:12 PM
forsure man thankss
Ryanman
Jan 6, 2008 10:03 AM
elmalouno
11
Aug 18, 2004 09:06 AM
zdr262
Jul 21, 2003 08:34 PM
wickedxboi
Mar 22, 2003 01:51 PM
Teg4e
May 8, 2002 03:49 AM
