HELP!!! cel's everywhere!!
Old May 6, 2012 | 03:27 PM
brandynEG's Avatar
Default HELP!!! cel's everywhere!!
I have a '92 vx hatch that I just swapped a boosted z6 into and after initial start up I had cel for a code 6 which is coolant temp sensor. one day after puttin' it up and down the street I now have a code 4 (crank pos. sensor) and a code 5 (manifold absolute pressure). and still the code 6. I've gone over all of wires, the dizzy is relatively fresh, and its on a z6 boost basemap. any ideas?!?!?
Old May 6, 2012 | 03:29 PM
Dc4LsTeG's Avatar
EK9
Default Re: HELP!!! cel's everywhere!!
Stock ecu?
Old May 6, 2012 | 04:26 PM
brandynEG's Avatar
no its a socketed p28 on a z6 boost basemap. another thing is that its not in limp mode which normally it would be with a code 4.
Old May 6, 2012 | 08:03 PM
zcme's Avatar
Map and tp plug mixed up? ect and vtec pressure sometimes get mixed? The 4 is either the distributor open or shorted wire or bad ecu. If that ecu and harness where working before..............
Old May 7, 2012 | 07:40 AM
brandynEG's Avatar
ya the ecu and dizzy were fine 2 days ago.. and I'm 90% sure I got the plugs right. I looked up the wire colors and pins on the ecu and they were correct.
Old May 8, 2012 | 03:43 PM
brandynEG's Avatar
Well after snugging up some wires to the ecu I got rid of the code 4 and 5.. I still have a code 6 for ect sensor. I tried a different sensor and checked the wire at the ecu. I'm stumped. has ANYONE else had this issue??
Old May 9, 2012 | 02:12 PM
brandynEG's Avatar
got a basemap from phearable.. open to any ideas on why this ect sensor code is still here. do i need to get the vehicle up to operating temperature after i try a new sensor? does my fan need to be hooked up?
Old May 11, 2012 | 11:12 AM
brandynEG's Avatar
I know there's somebody on this website who has the answer...
Old May 11, 2012 | 12:51 PM
Gunmetal_B20_Hatch's Avatar
check thermostat ground...
Old May 11, 2012 | 03:55 PM
brandynEG's Avatar
checked that.. its fine.
halfdemonpyro
Aug 2, 2012 03:18 AM
happyabortion
May 13, 2008 04:18 PM
lscrxhf
Jul 4, 2006 08:08 AM
USDM 4G VTEC
11
Jul 15, 2003 11:05 AM
