TPS ground volts question
Old May 2, 2012 | 09:45 AM
CGcivicGSR's Avatar
Default TPS ground volts question
I'm having tps issues I no how to set it manually I'm getting good reading which are red wire 0.50 volts yellow wire 5.00 volts and green wire is 0.03 and its suppose to be 0.01 could this be reason for low rpm sputtering ect also what I thought is really weird is when I disconnect the tps plug it dosnt through a check engine light thanks for any insight ,,oh car is eg h22a turbo hatch running hondata just built the block ,,I'm just trying to get the car running good soo I can drive it to get tunned thanks
Old May 2, 2012 | 09:55 AM
CGcivicGSR's Avatar
Default Re: TPS ground volts question
Oh and yes the check engine bolb is in there car runs idles high though like 1500 rpms,, this car is taking over my life lol no seriously
Old May 4, 2012 | 05:23 AM
CGcivicGSR's Avatar
Update was just a bad basemap
giddyup21
Mar 18, 2012 06:49 PM
russ2169
Oct 24, 2009 03:55 PM
Dwalker
Feb 10, 2008 06:41 PM
krops13
Jan 3, 2008 03:23 PM
1sikhatch
Dec 22, 2005 01:03 PM
