Vtec not engaging ( ectune)
Old Apr 25, 2012 | 06:01 PM
BoostedEgHatchFl's Avatar
Default Vtec not engaging ( ectune)
I just got my motor back from being rebuilt by my tuner. Im running the same map as the last dyno session when the hg blew. I was getting a check engine light every time when vtec would try to engage. Now its running just fine just no vtec. I check the wires and they r fine. Is there any other ways to test so I can figure out the problem.....
Old Apr 25, 2012 | 06:13 PM
Dc4LsTeG's Avatar
EK9
Default Re: Vtec not engaging ( ectune)
Don't double post in different sections
Old Apr 26, 2012 | 10:06 AM
mtber's Avatar
Simply check for voltage on the solenoid wire using a volt meter when the car is supposed to be in vtec. If you are seeing 12 volts but don't have vtec then the problem is mechanical...
Old Apr 26, 2012 | 01:39 PM
Is there anyways to text the solenoid and spool valve?
Old Apr 26, 2012 | 06:32 PM
david974's Avatar
put 12v on the solenoid to see if it still moving
remove it before
Old May 1, 2012 | 03:15 PM
I out 12 volts to it and it clicks like its suppose too. I check for continuity from the ecu pin to the sol and its good. I know its not in the tune. I took the sol off and cleaned it and put a new gasket/filter on it. I ran a wire off the the vtec sol right beside the sol into the car and its getting 12v... IDK what else it could be....
Old May 2, 2012 | 12:43 AM
david974's Avatar
Try another ECU, perhaps the Vtec solenoid driver or transistor is dead
Old May 2, 2012 | 01:44 AM
Well Im getting 12 volts to when sol when Im suppose to be.
BoostedEgHatchFl
Apr 25, 2012 06:11 PM
swizz977
10
May 25, 2011 08:15 PM
zcarkid
11
Dec 25, 2007 09:45 PM
twentyhurtz
Apr 30, 2006 05:38 PM
delsolrmp
Nov 15, 2003 07:46 AM
