Is this P30 ECU chipped?
Old Jun 11, 2012 | 01:51 PM
pandarex's Avatar
Default Is this P30 ECU chipped?
I bet these pop up a lot, I've searched around on a couple different websites, and haven't really found enough info to make me feel comfortable without asking someone with a little more knowledge. Here are some pics.
I ca see J1 has been messed with, but it looks like they pulled the jumper back off?
Sorry I couldn't get better pics, I can if someone can help.
Old Jun 11, 2012 | 02:29 PM
GhostAccord's Avatar
Default Re: Is this P30 ECU chipped?
Yes it has been modified to accept an alternate ROM chip. That is what the 28 pin socket is there for. However, the 4 pin CN2 connector for the datalogging circuit has not been added. Also there is no resistor in C92 where there should have been one added.
J1 has probably been pulled becuase they messed up the chipping procedure and left out a few resistors. The ECU was more than likely throwing a solid CEL all the time when the jumper was installed.
Are there resistors added to C49, C50 and C91 on the back? I can see that there isn't one in C92 and there should be.
Old Jun 11, 2012 | 03:57 PM
pandarex's Avatar
c49 - no
c50 - no
c91 is in the last pic right? It's not the 20 pin? If its the spot next to it its empty as well
What can I do about getting it back to stock? or is it?
Old Jun 11, 2012 | 05:18 PM
If the J1 is open (no jumper) your ECU should be running off the stock ROM chip.
Old Jun 11, 2012 | 06:10 PM
pandarex's Avatar
it appears to be open, but as you can sorta see from the picture, someone did a very terrible job. Thanks for your help.
Old Jun 12, 2012 | 11:43 AM
You're welcome! Hopefully they didn't mess up the ECU too badly.
95sloweg
Jan 14, 2008 05:46 PM
bleedblue94
11
Apr 6, 2006 04:07 PM
91d15bvtec
May 11, 2005 03:57 PM
5STAR3
Mar 20, 2004 04:40 PM
SloCivicHMM
10
Apr 30, 2003 08:02 AM
