C27 valves
Old Apr 6, 2012 | 09:28 AM
Wolf_USAR's Avatar
Default C27 valves
Not sure if I'm posting this in the right thread.
1996 Honda Accord LX V6 - C27 engine with 182k miles
Valve train sounds like an angry typewriter at start up, and just a little less angry when it get warm. I put on a new head gasket set (due to stripped head bolt from the factory) and timing belt at 160k.
Dealership quoted me at $500+ due to "5 hours of estimated labor and shop costs." Does this sound right or are they just yanking my chain? I read on a prior post that you can't adjust these valves. If that's so, how does it take 5 hours to "not" adjust the valves? I've already tried using heavier weight oil, any advice?
Old Apr 6, 2012 | 01:04 PM
GhostAccord's Avatar
Default Re: C27 valves
$500 for valve adjustment, parts and labour on a V6 sounds pretty cheap actually! As long as they are replacing all of your valve cover gaskets that is.
Last time I went into the dealership and asked them for an I4 F22B2 timing belt and valve adjustment. They quoted me $800. That is parts and labour included. I walked out the door and did it myself in a day out in my garage for a few hun in parts and a case of beer.
Old Apr 7, 2012 | 08:24 AM
Gunmetal_B20_Hatch's Avatar
You probably have to pull the upper plenum to adjust the valves on the rear bank... Thats probably where a bit of the $$$ comes in also.
grinder_1
Classic Hondas
Feb 17, 2026 01:44 AM
raverx3m
May 18, 2011 11:24 PM
vxnine
12
Oct 14, 2004 07:41 AM
mickey513
Feb 19, 2002 10:50 PM
