only able to tune WOT????
Old May 2, 2012 | 09:02 AM
notsolfast's Avatar
Default only able to tune WOT????
So I was talking to my tuner the other day about my simple b16 turbo setup. I'm running open downpipe that ends right about at the middle of the flywheel cover. The o2 sensor hold is about 7 inches away from the turbo. He said he won't be able to tune idle or partial throttle. Is this true? Should I extend my exhaust a little bit?
Old May 2, 2012 | 10:16 AM
GhostAccord's Avatar
Default Re: only able to tune WOT????
IMO you should find a new tuner!
Old May 2, 2012 | 10:22 AM
mouab18c1's Avatar
Old May 2, 2012 | 11:06 AM
notsolfast's Avatar
They're a legit tuning shop though. Good reviews and whatnot. He said the o2 sensor would see too much fresh air? Sounded weird to me, but I'm not a tuner
Old May 2, 2012 | 11:12 AM
OK so you mentioned that the O2 was 7" from the turbo. How far is it from the end of the exhaust?
If you feel that they are legit then why question them? You should do what they recommend you to do....
Old May 2, 2012 | 11:16 AM
notsolfast's Avatar
Its about a foot away. And there's a 45 degree ben on the pipe too. I just don't want my partial throttle to suck or my idle
Old May 2, 2012 | 11:22 AM
12" may be a bit short, however, what did your tuner tell you would be the minimum length he could tune with? I guess that would be your best bet to keep him happy. and a happy tuner makes for a happy customer.
There are tuners ou there that use the tail pipe sniffers to tune.
Old May 2, 2012 | 11:41 AM
notsolfast's Avatar
Yeah, he's using a wideband to tune. If he can't tune partial throttle does that mean I will have no power until I step on it all the way?
Old May 2, 2012 | 11:45 AM
Who are you having tune your car?
Old May 2, 2012 | 11:50 AM
notsolfast's Avatar
Innovative tuning in buffalo
Old May 2, 2012 | 11:53 AM
To be honest with you, you should ask them these same questions and see what they say. Better to get to know your tuner than to get misinformation online.
We don't know what your tuner can and can't do or what they prefer.
Old May 2, 2012 | 05:44 PM
Gunmetal_B20_Hatch's Avatar
I understand his theory behind not wanting to tune part throttle/idle w/ such a short exhaust, but its still not that hard to read... I have no problems getting accurate AFR's on my open DP. My WBO2 is only 6" away from the end of the pipe.
Old May 3, 2012 | 03:48 AM
non-VTEC's Avatar
my wbo2 is in the stock location which is a good 12-14" away from the turbo and im able to tune idle and part throttle very well..
your tuning is giving you wrong information or you miss understood him.....OR he just sucks.
Old May 3, 2012 | 10:37 AM
Motox122jk's Avatar
IMO if he's not comfortable tuning the way it is, why not just find out how much of a tail section he would like put on? Can't cost jack and it will put him in his comfort zone.
Vryantec
Engine Management and Tuning
18
Jul 31, 2018 03:35 AM
jagojon3
Jun 29, 2005 11:47 AM
the.hamburglar
Jun 12, 2005 03:47 PM
92HB_HB
May 11, 2005 06:06 AM
gamakichi77
Mar 18, 2005 05:12 AM
