will I need a re-tune??
Old May 25, 2012 | 06:37 AM
notsolfast's Avatar
Default will I need a re-tune??
okay, so the other day my car started throwing a code 9 which is for cylinder position sensor. I was going to get a new distributor and put it on but I wasn't sure if I had to like but it on a certain way because I just had it tuned. It's a stock block b16 turbo.
Old May 25, 2012 | 06:42 AM
mtber's Avatar
Default Re: will I need a re-tune??
You will need to sync your distributor timing to set it where it was when the car was tuned on the old distributor.
Talk to your tuner.
Old May 25, 2012 | 06:50 AM
notsolfast's Avatar
is that what a timing light is for?
Old May 25, 2012 | 08:03 AM
mtber's Avatar
Yes, however you will need to confirm with your tuner what he set your base timing at.
Old May 25, 2012 | 01:40 PM
notsolfast's Avatar
okay. Has anyone had this code 9 before? Am I good to drive with it? It runs perfectly fine with no misfires or anything, just the light on
Warren_LowSol
Jan 18, 2018 12:22 PM
Chukyx3
Feb 28, 2016 05:42 AM
B16Blake
Nov 30, 2009 09:18 PM
meallout
Mar 19, 2009 11:34 AM
typeeg
Jun 23, 2004 04:22 AM
