ej speed limiter
Old May 27, 2012 | 04:01 PM
racerx510's Avatar
Default ej speed limiter
i have a buddy who was wondering how to adjust the speed limiter, he wants to set it at about 80 without having to worry about how hard he presses on the gas pedal or whatever.
any help is appreciated and i am actively researching this otherwise and have only seen flashpro as a result thus far
Old May 27, 2012 | 04:03 PM
Dc4LsTeG's Avatar
EK9
Default Re: ej speed limiter
you can set a speed limit with Hondata. But why?
Old May 27, 2012 | 04:18 PM
racerx510's Avatar
a very... very interesting piece of "proof"
dam though, hondata ain't cheap and hondata is flashpro
Old May 27, 2012 | 04:20 PM
Dc4LsTeG's Avatar
EK9
Oh you mean aint cheaper then the speeding ticket your friends trying to get out of?
Old May 27, 2012 | 05:29 PM
racerx510's Avatar
actually it's probably twice as much. i figured it can be proven via in car camera work and a long empty lot. the throttle cable can be unbolted from the body and rigged so that it catches the further down the gas pedal pressure. further, you can zip tie the loose cable to the wheel on the throttle body so it's not able to just fly off.... secure... ghetto.... but secure enough to provide evidence in car thus far... now, i find it interesting that a question ej specific because the resulting electronics may be ej specific has been moved to a "generic" thread so quickly by the honda-tech ****'s
Old May 27, 2012 | 05:47 PM
racerx510's Avatar
msd rev limiter module... problem solved. if i can tune 80 mph in 5th gear @ X,000 rpm then it's set
Old Jun 9, 2012 | 09:24 AM
racerx510's Avatar
so, i guess now the question is. any reccomendations for a good rev limiter?
Old Jun 9, 2012 | 09:35 AM
racerx510's Avatar
http://www.amazon.com/Programmable-L...263165&sr=8-27
Old Jun 9, 2012 | 10:13 AM
Bix VT's Avatar
This seems like a lot of trouble, cost, and hacking up wiring. Why not just pay the ticket and keep the speed reasonable?
Old Jun 20, 2012 | 05:02 PM
racerx510's Avatar
actually... its a lot easier then converting to vtec. im a wire guy, my eclipse gsx i wired my own apexi avcr, turbo timer. takes less then half an hour for most of these
jhawker23
Oct 4, 2016 08:15 PM
Walkie Talkie
Jan 30, 2012 05:02 AM
Aeka GSR
Apr 28, 2004 09:26 AM
Boostage
Feb 23, 2004 01:53 PM
2K_TEG
Feb 7, 2003 07:50 AM
