head gasket changing
Old Jun 15, 2012 | 11:56 AM
chandlerM13's Avatar
Default head gasket changing
i have a D15B block in my honda and i believe the head is a b16? i really dont know but the shop i took it too said that it was.
so my question is, when a put the head gasket on do i go with the block? or head?
the place i went too put the 1.6 valvue seals in the head and used the head gasket from that kit and i blew my head gasket.. so thats obviously not right.
so another question, should a change all the seals they put on the block? or will they be fine as the 1.6 seal kit?
i dont know much.. so please help me
Old Jun 15, 2012 | 12:01 PM
Dc4LsTeG's Avatar
EK9
Default Re: head gasket changing
You need to find out what head you have. Its not a b16, did you mean d16?
Old Jun 15, 2012 | 12:05 PM
GhostAccord's Avatar
I can't help you directly however I can help point you in the right direction. This particular sub forum is for Engine management & tuning questions or information. In my opinion you would probably have better luck posting this question in the Civic sub forum.
Old Jun 15, 2012 | 12:06 PM
ok, so if its a D16.. how do you tell?
MigsD16
Engine Machining & Assembly
Dec 17, 2016 05:17 PM
chandlerM13
24
Jun 16, 2012 10:24 AM
strike1545
May 24, 2010 10:42 AM
Joker_God
12
Nov 30, 2009 01:34 PM
john457
Jun 26, 2007 05:48 PM
