how much will elevation and weather difference affect a tune?
Old Jul 18, 2012 | 07:44 PM
doood's Avatar
been there done that
Default how much will elevation and weather difference affect a tune?
quick rundown of the motor:
k20z1
rbc
cai
race header no cat
2.5'' exhaust
i was street tuned almost a year ago when i was living in socal right before i moved back to norcal. only major change since then has been a built tranny with lsd and 5.0FD, engine has stayed the same. elevation was around 2000ft and temps around 80-90*. 3rd gear WOT datalog from that session shows afr holding steady around 13.5:1 from 2k-8.6k rpm.
today i was at the drag strip and did some datalogs from 1-4 and they showed afr around 16:1 at WOT! elevation where i'm at now is around 30ft and temps were about 80*.
i didnt think the change would be so drastic. hopefully i can get retuned by a local shop within the next two weeks but now i'm afraid to even drive the car.
Old Jul 18, 2012 | 10:49 PM
Dc4LsTeG's Avatar
EK9
Default Re: how much will elevation and weather difference affect a tune?
Do you know what the iats were for each datalog? And you did mean 30ft right?
Old Jul 18, 2012 | 11:35 PM
doood's Avatar
IAT's for these recent runs were only 4-5 degrees cooler than the ones from last year. google says elevation here is anywhere from 20 to 40 feet so i just went in the middle.
Old Jul 18, 2012 | 11:41 PM
Dc4LsTeG's Avatar
EK9
Yea im not sure I'd expect to see some change but not that much.
Old Jul 20, 2012 | 09:48 AM
doood's Avatar
any other input?
Old Jul 20, 2012 | 12:08 PM
2k.civic.si's Avatar
if the correction tables are setup right altitude should make little difference to your air fuel ratio. if it was tuned at lower altitude on a dyno the only thing you would really change at high altitude would be timing...the higher you go the more you can bump timing do to the drop in atmospheric pressure.
if your a/f ratio is changing drasticly with altitude change you need to make adjustments in the correction tables....fuel curves should remain the same.
Old Jul 23, 2012 | 04:52 AM
scmil95eg's Avatar
Originally Posted by doood
any other input?
10% per every 1000 meters (~3300 feet).
Or you could say ~3% per every 1000 feet.
smilindave
Transmission & Drivetrain
Jan 19, 2018 12:22 PM
doood
11
Jun 8, 2012 03:34 PM
4 door beast
May 30, 2009 04:46 PM
Skadaloz
Aug 17, 2008 04:05 PM
wantboost
Nov 25, 2005 01:49 PM
