Help: Weird Ignition "Misfire"
Old May 3, 2012 | 02:11 AM
extremeracer's Avatar
Default Help: Weird Ignition "Misfire"
Hi guys
Firslty, this is not another "I have ignition break-up on stock ignition - what do I do"
I am experiencing a slight "miss" at 6500 rpm which is not related to load or boost
My initial setup was as follows:
B18
84 x 89mm
9:1 CR
B16 Head
Xenocron chipped ECU
eCtune
Stock leads
Stock Ignition
Holset Super HX40 turbo
I experienced spark break down @ 6500rpm with this setup at anything over 20 psi boost. I then established that my plug gap was too big but decided to upgrade the ign system in view of running Ethanol
New Setup
MSD Digital 6 Plus
MSD Cap
MSD Blaster HVC coil (Big blue one)
Magnecor leads
>> The car still has the 6500rpm "miss" and we checked the spark and there is a big blue spark. It is also unrelated to load as it does it at part and full throttle.
Swapped caps, leads, rotor, plugs - with no improvement
I am totally lost and frustrated with this now !!
Any ideas - can this be related to dwell in the ECU ??
Old May 4, 2012 | 07:25 AM
xenocron's Avatar
Default Re: Help: Weird Ignition "Misfire"
My guess would be a bent shaft ever so slightly in the dizzy, or an old/tired pickup in the dizzy.
Try changing the whole distributor. Generally when you see an "issue" at one particular RPM point or range, its a resonance or oscillation that is created by rotational harmonics, and there is really nothing you can try except swapping out the dizzy.
Old May 4, 2012 | 02:09 PM
Gunmetal_B20_Hatch's Avatar
I would imagine that a faulty ignitor could be causing this issue also... Not 100% sure though.
I like the idea of a resonance in the cam/crank pickups, too. Either way, I would try another distributor.
Old May 4, 2012 | 02:26 PM
civickiller's Avatar
try close the gap in your spark plugs
Old May 7, 2012 | 10:59 PM
It turned out to be the module (ignitor). I had it tested whilst heating it up with a heat gun and as it gets hot it starts acting up.
Changed to a different distributor and problem was solved, installed a new ignitor in my external coil/MSD converted distributor and no more problems either
Thanx for the input
extremeracer
Engine Management and Tuning
Mar 24, 2012 06:39 AM
92HB_HB
Apr 15, 2004 12:50 PM
BLKCRX
Jan 15, 2003 07:51 PM
SiRkid
Oct 31, 2001 01:16 PM
