Afr reading different
Old Jun 23, 2012 | 05:36 PM
jaydmdude's Avatar
Default Afr reading different
Wideband: innovate mtx-l
Program: Crome pro
Hey all, I am having a slight problem with the Afr syncing together for my Wideband and crome pro. I used the yellow wire and hooked it up to the datalogging wire on the ecu. I went to the settings in Crome and changes the Wideband output to and innovate wideband's output but the readings are still off(I.e. mtxl will read 14.5-15 at idle but in Crome, it reads high 15-16s). Anything ?
Old Jun 23, 2012 | 06:24 PM
GhostAccord's Avatar
Default Re: Afr reading different
Go in where you selected the innovate wideband and change the Lambda offset correction until your gauge and Crome datalog match.
Crome/file/settings/tuner logging - Offset Lambda (+/-) 0.00 (default)
Old Jun 23, 2012 | 07:42 PM
jaydmdude's Avatar
May have found the problem. Hooked up the ground of the wideband to the battery and it seems to have solve the problem. I'm surprised the response time of the innovate is a lot slower than the plx m300 that i've had before.
Infamous war
Engine Management and Tuning
Jul 29, 2012 04:12 PM
omgherb
Feb 18, 2007 03:48 PM
EJK
Apr 24, 2002 01:58 PM
EJK
Apr 16, 2002 04:47 PM
