pr4 ecu trouble codes
Old Apr 27, 2012 | 02:53 PM
B18dego's Avatar
Icon6 pr4 ecu trouble codes
i have a pr4 ecu and it is flashing 3manifold absolute pressure 8 tdc position and 13 atmospheric pressure what do i need to do to fix these codes ???
Old Apr 27, 2012 | 02:57 PM
Dc4LsTeG's Avatar
EK9
Default Re: pr4 ecu trouble codes
Year/make/model?
Old Apr 27, 2012 | 05:53 PM
zcme's Avatar
Manuals can be found at www.hondatech.info run the diag for each code. In general its ether a sensor, ecu or wiring problem.
Map and tp sensor connectors can easily be mixed they also share the same 5v ref and ground iirc. The distributor code stands alone and is probably unrelated to the two other codes.
Old Apr 28, 2012 | 06:30 PM
B18dego's Avatar
ita a 91 civic dx with a 94 b18b1 ls engine non v tec
Old Apr 28, 2012 | 06:42 PM
B18dego's Avatar
if any one is in the lansdale area and can help me out that would be great
jdm inc
Engine Management and Tuning
Jun 16, 2012 10:41 PM
Hgoku10
Aug 4, 2009 09:05 AM
hybrid1990crx
Apr 6, 2006 03:05 AM
Eg6_JDM
Mar 19, 2002 01:35 PM
.brad
Jan 21, 2002 02:01 PM
