Hondata Ventuli
Old Apr 7, 2012 | 09:58 PM
9tailsfox's Avatar
Default Hondata Ventuli
hello, Is this Hondata Ventuli plate made for b16a. Some say this Hondata Ventuli plate cause mid rpm range rpm gain some hp but lost at high rpm range power. i thought this Ventuli plate just a rubber that reduce the IM heat soak. But why it would cause high rpm range power lost? Thank you
Old Apr 8, 2012 | 08:06 AM
zcme's Avatar
Default Re: Hondata Ventuli
The hondata heat shield intake gaskets are designed to reduce intake heat soak. The ventuli plates change the intake runner sizes where the intake gasket is (makes them smaller) this is where the top end loose is created.
Old Apr 8, 2012 | 04:38 PM
canadaek's Avatar
how the hell did you understand that ?
BlUAc
Jun 20, 2006 04:55 AM
dohdoh420
Dec 2, 2005 08:57 PM
Grip
21
Jul 23, 2004 07:51 AM
1.8T_EG
Apr 10, 2003 04:06 PM
F1HONDA
77
Oct 27, 2002 02:11 PM
