ectune ebc solenoid ecu work?
Old Jul 10, 2012 | 02:22 PM
bigblue7t6's Avatar
Default ectune ebc solenoid ecu work?
Ok guys, I have downloaded the pdf about the electronic boost control solenoid, it says it requires the sk5151 (or equivalent) in the ic16 slot, and d13 1n4004. I understand that it says that this stuff may already be present in the ecu. My ecu is an auto so it does have the lock up transistors in ic16 and ic17, but it is a p06 so they are the sk5050s, i know that the sk5050s are not acceptable to use for vtec conversions in the ic15 slot, but do the sk5050s work for the ebc control? Also was wondering if you needed to still remove the resistors from rp17 and rp18 and jumper the rp18 back like you would normally do to convert it to a manual ecu, or does that disable the transistors at the ic area.
Thanks
Old Jul 11, 2012 | 05:33 PM
xenocron's Avatar
Default Re: ectune ebc solenoid ecu work?
EBC control doesnt need any Sk5151s....you need PWM components (EGR circuit).
http://www.xenocron.com/hondata-s300...nts-p-226.html
http://www.xenocron.com/install/PWM-...00-neptune.htm
Old Jul 16, 2012 | 02:54 AM
bigblue7t6's Avatar
Thanks for the reply. Yes the way I understood it I need the PWM components to add that function to pin A11, but if I was looking to add the function to the A17 pin it only requires a diode at D13 and one of the SK5151 switches at IC16, am I reading that completely wrong?
marcj
Jul 11, 2009 07:05 PM
akouznet
May 24, 2009 06:50 PM
candyblueta
Engine Management and Tuning
Jan 8, 2009 07:34 PM
DuronClocker
10
Jan 2, 2008 08:11 PM
rrei
Feb 3, 2003 10:42 PM
