Tune changes when the headlight are turned on
Old Apr 12, 2012 | 06:51 AM
si90rex's Avatar
Default Tune changes when the headlight are turned on
94 honda civic b20 turbo 9 psi with dsm injector w/ resistor box. I street tuned it and it makes really good power, but at night when i turn the headlights on the car leans into the 18's only at 0%-to 15% throttle, under boost its dead on 12.2-11.9. I have check the thermo ground, valve cover, starter and battery. any suggestions? Never had this problem before. I had two other motors in the car running fine when i tuned them.
Old Apr 12, 2012 | 07:28 AM
Bix VT's Avatar
Default Re: Tune changes when the headlight are turned on
Have you checked the alternator?
Old Apr 12, 2012 | 07:33 AM
HRTuning's Avatar
Injector dead times.
Old Apr 12, 2012 | 05:00 PM
zcme's Avatar
This also call latency depending on the program used.
Old Apr 12, 2012 | 06:19 PM
si90rex's Avatar
alt 13.7v
what is dead time is it correctable?
I used crome pro
Old Apr 12, 2012 | 06:46 PM
si90rex's Avatar
Ok i just realized i did not change the Battery offset to the dsm injectors which would cuz some problems when the voltage drops from the headlights. I'll check into this tomorrow.
Old Apr 13, 2012 | 06:13 PM
si90rex's Avatar
I changed the battery offset and it seemed to help. i didnt get to drive the car cuz its raining so bad but i will have to touch up the fuel table just a little. Thanks for the help.
Old Apr 14, 2012 | 02:24 AM
Westrock2000's Avatar
Hell with rain, what about Tornado's? Be safe up there this weekend.
Old Apr 14, 2012 | 03:38 AM
portenio78's Avatar
True that. Weather was nasty!
Old Apr 14, 2012 | 10:59 AM
si90rex's Avatar
Thank you very much. That means alot we lost my cousin in last years tornado. No one around here thinks twice when the sirens go off any more.
Misty Taylor
Honda Civic (2001 - 2005)
Aug 28, 2019 11:38 AM
alperx
Engine Management and Tuning
Sep 20, 2011 08:57 PM
krs6i5
Honda Civic (2006 - 2015)
Apr 10, 2011 01:53 PM
intxactdgsr
Dec 23, 2004 07:17 AM
DJ0820
26
Dec 22, 2002 03:30 PM
