ecu for my car
Old Jul 20, 2012 | 07:37 PM
killudie123's Avatar
Default ecu for my car
i have a 00 b18c5 swapped in my em1. if i use a 96-98 p73 obd2a ecu will it run fine? im currently using a chipped ecu and dont like the fact that it has no redline on it. any info greatly appreciated. thanks.
Old Jul 20, 2012 | 07:47 PM
Fliptard's Avatar
Default Re: ecu for my car
Search ebay for companies like Rich Tuned and such. Ask them for an OBD1 p28 or P72 and chip it for your car/motor, set a rev limitor where ever you would like. Get free added features like 2-step launch control, delete ELD, 02, Knock sensor or such.
Old Jul 20, 2012 | 07:59 PM
mtber's Avatar
You do not need a new ecu.
Assuming you have a chipped/socketed obd1 p28 spec ecu:
You may order a 28 pin eprom chip basemap from our website
http://www.phearable.net/shoppingcar...emap-p-60.html
& drop it into the ecu your self.
There is an instructional video on our website on how to change your eprom chip in an already socketed ecu.
http://www.phearable.net/tech
Old Jul 20, 2012 | 11:22 PM
shiroitenshi's Avatar
chip it with a JDM ITR or equivalent ECU map like above suggestion.
Old Jul 21, 2012 | 01:50 PM
this is what i have
Old Jul 21, 2012 | 01:51 PM
sorry for massive piks!!
Old Jul 22, 2012 | 01:09 AM
still chippable, remove the 28 pin chip from socket and upgrade to a chip with a rev limiter
Old Jul 22, 2012 | 11:38 AM
mouab18c1's Avatar
It's already been chipped. He just needs a basemap now
Old Jul 22, 2012 | 12:19 PM
this is what i thought. how much do they go for?
Old Jul 22, 2012 | 02:46 PM
mtber's Avatar
Old Jul 24, 2012 | 01:15 PM
^^^ so for this i get a chip in the mail and plug and play? hmm seems a little to easy.
Old Jul 24, 2012 | 01:44 PM
mouab18c1's Avatar
Correct.
Old Jul 30, 2012 | 05:05 PM
Julio@Bisimoto's Avatar
Icon3 Re: ecu for my car
Engine management should be everyone's number one investment whether being a stock engine or a full blown competitive race car. It is the one item that will be controlling all your engine parameters and determining crucial fuel and ignition maps.
I would say why risk issues with modifying 20+year old factory ecu that also require a jumper harness which can lead to additional problems. With technology progressing as quickly as it is today I would recommend just investing on a stand alone system such as the AEM EMS Series 2 which will plug directly into your factory ecu plugs with no wire modification necessary and is available for OBD-1, OBD-2a and OBD-2b for typical B,D,H and F-series engines. Not to mention available also for K-swapped setups and the S2000.
With the AEM EMS Series 2 you will have brand new hardware as well much more sophisticated software allowing for a superior tune of your fuel and ignition maps. Not to mention all the countless additional features built in that can been very beneficial to your setup now and even for future modifications.
Such as closed loop operation with an AEM UEGO Controller allowing for accurate auto correct of fuel mapping while you are racing/driving and even Coil on Plug setups to replace your entire ignition system including your distributor with a much more accurate and reliable sensors giving you much more control over your ignition system and greater spark capabilities for high rpm/high cylinder pressure setups as well as on board datalogging, launch control, traction control and much more!
Old Jul 31, 2012 | 09:32 PM
99V-unit's Avatar
I can make you a map and send it to you with a chip. Where you located?
I have a few tuned itr maps. (every motor is different, however, it should put you in the ball park)
Old Aug 1, 2012 | 04:45 AM
scmil95eg's Avatar
Julio - I'm with you 100%, I've had AEM on my DD for, well, forever lol. But based on the context of this thread, do you really think the OP is ready to be turned loose on a full stand alone system?
From my experience, learning about engine management isn't for everyone and you can't teach someone who really doesn't want to learn. And when that's the case, they'll have more fun playing on a level that's a little easier to understand.
Old Aug 1, 2012 | 09:58 AM
Basik_One's Avatar
If you plan on modifying the engine then go obd1 so you can tune. If its going to remain stock might as well get a stock ecu (p73) obviously, specially if you have to pass emissions.
Old Aug 1, 2012 | 02:27 PM
i dnt really have the cash for a stand alone at this time. iv been looking for a obd2b p73 but iv come to realize it is almost impossible and i would need it with the immobilizer removed
Old Aug 1, 2012 | 07:00 PM
spAdam's Avatar
Loved
Community Favorite
It's not that impossible. For one, the immobilizer can be bypassed.
http://www.doctronic.at/Mobilizier_Board_E.htm
I'm not sure which board the p73 uses, this guy sells two versions.
Old Aug 1, 2012 | 07:40 PM
^^^ thats a little more then i would want to mess with the ecu.
Old Aug 1, 2012 | 07:41 PM
pm me
Old Aug 2, 2012 | 03:35 AM
spAdam's Avatar
Loved
Community Favorite
It involves less pins than installing a socket...
Honestly though, if you're not opposed to an obd1 conversion just get a basemap from mtber. He sells a great product and since your motor is mostly stock you shouldn't have any worries running on a base until you get more work done and require a proper tune.
Old Aug 2, 2012 | 11:10 AM
got it in the mail the other day, it threw my cel light, my idle was all messed up after reving it up 2xs and the v tec didnt kik in until 6400 rpm. the only thing that werked great was the 2 step, i put the old chip back on it and it went back to normal no cel light, idle back to 700, vtec at 6000rpm but no 2step
Old Aug 2, 2012 | 11:49 AM
spAdam's Avatar
Loved
Community Favorite
That's not normal for a phearable chip. PM John and see if he can assist you.
HAMOTORSPORTS
Performance
172
Sep 29, 2017 11:00 AM
DA_PoWeR
Engine Management and Tuning
Aug 27, 2010 05:37 AM
hondaEg_808
Mar 25, 2008 11:10 PM
option2type6
Northeast (Sales)
Nov 18, 2007 03:02 PM
B16aSir2
Feb 20, 2006 04:29 AM
