engine tuning question
Old May 15, 2012 | 03:50 AM
alperx's Avatar
Default engine tuning question
hi
When an engine is properly tuned at let's say 300 hp with stock sleeves on a honda b18a1 engine, is there a possibility for the sleeves to be cracked after some driving (e.g. after 5000 miles) even if there has been no changes made to the engine ?
regards
Old May 15, 2012 | 06:33 AM
kyden's Avatar
Default Re: engine tuning question
anything is possible, but that isn't common at all at 300hp when tuned correctly.
Old May 15, 2012 | 06:37 AM
2000CTRSi's Avatar
If u somehow have a fuel system failure for exampl rgulator or stuck injector, or even coolant failure causing heat, then yes. Harsh antilagging can hurt it too
Old Jul 11, 2012 | 01:52 PM
mouab18c1's Avatar
www.hrtuning.com
JR will reply faster on there to your Neptune RTP questions.
Old Jul 11, 2012 | 05:25 PM
grumblemarc's Avatar
The Grumpiest
Originally Posted by mouab18c1
www.hrtuning.com
Apparently not fast enough. I directed him there earlier and he caught an attitude.
Old Jul 11, 2012 | 05:35 PM
Gunmetal_B20_Hatch's Avatar
yes
Old Jul 11, 2012 | 09:43 PM
Dioxine's Avatar
to the OP 5000 miles of "driving" ore then likely it will be fine. 5000 miles of "driving the crap out of it" might lead you to some stress cracking. I beleive the sleeves are good for up to 400 max but thats pushing your luck and running on borrowed time. 300 to 325 is a good stopping point if you want to put some miles on it.
Old Jul 12, 2012 | 08:41 AM
HRTuning's Avatar
Not sure what you mean. I answered his questions in the morning before he posted here. He's just going to have to play with the 2-step settings and find what works best for his setup.
Old Jul 12, 2012 | 08:43 AM
The Grumpiest
I meant fast enough for his liking. He claimed in his other jacked thread that no one was answering him but I knew that wasn't possible.
Old Jul 12, 2012 | 08:49 AM
HRTuning's Avatar
Gotcha. Ya, never possible.
Old Jul 12, 2012 | 09:51 AM
The Grumpiest
Good luck guy. I've owned a Prelude before and my initial tune was done on CROME. I have a nice shiny RTP sitting in it now but I really don't care what you think. You're the one that cannot get his car running straight even after the advice of the pros over at HRTuning.
Just admit you don't understand what you need to do and stop being so arrogant.
Again, good luck to you sir. (BTW. Why are you deleting all your posts?)
Old Jul 12, 2012 | 10:17 AM
4thgen DragLude's Avatar
I don't understand that's why I'm here asking questions. Is this your first time? The reason people ask questions is because they don't know and would like to so they ask.. hence why I have been asking questions.... Once again you type a lot but say nothing.
Old Jul 12, 2012 | 10:19 AM
I'm not sure why you keep responding you haven't said one bit of info and you've posted 20 times. well done sir you are a waste of time.
Old Jul 12, 2012 | 03:24 PM
boostedgeezer's Avatar
Originally Posted by alperx
hi
regards
We have been building Hondas for a long time now and most of them seem to have no problem on stock sleeves at that power level with a good tune. I will say that years ago at the 300 whp level we did have isssues with cracked ring lands and sleeves due to a bogus aftermarket distributor and the older AEM unit. I believe the signal was getting a little silly and adding a **** load of timing;. That has been the only issue ive seen at that power level. Last stock sleeve gsr we did made about 500 whp and was driven everyday for about a year and was fine.
AWDxBOOST
Honda Motorcycles
Sep 20, 2007 12:56 PM
EK FLY
Aug 6, 2005 08:52 AM
quik sol
Apr 10, 2005 12:55 AM
3sixtycrew
Jul 7, 2003 01:55 PM
GetawayInMoscow
Jun 23, 2003 09:43 AM
