Kpro D/C issue
Old Mar 17, 2014 | 08:25 PM
dbb95ex's Avatar
Default Kpro D/C issue
Anyone have a fix for the disconnect during WOT datalogging? Tried 2 different laptops, different cables, spark plugs.
Old Mar 19, 2014 | 11:13 AM
Muckman's Avatar
Moderator in Chief
Default Re: Kpro D/C issue
The disconnects are usually caused by RF interference. Make sure you are running resistor spark plugs and a USB cable with a ferrite core on it. As a last resort you can always use onboard data logging.
Old Mar 19, 2014 | 07:01 PM
dbb95ex's Avatar
Yeah, the plugs are resistor and as far as I know the cable is. We encountered the problem trying to do some street tuning, everything was fine til we started to wot pulls.
Old Mar 20, 2014 | 05:10 PM
VegasInvasion's Avatar
I'm Huge In Japan
RF interference can also be caused due to bad grounds, which I see with the RSX pretty frequently. remove all grounds, clean, reinstall.
And a ferrite core on a USB is pretty easy to identify, either it has one or it doesn't.
http://static4.depositphotos.com/100...th-ferrite.jpg
ACTION JACTION
Engine Management and Tuning
11
Jun 11, 2011 05:14 AM
i-VTEC_DOHC
Honda Civic (2006 - 2015)
10
Jan 24, 2010 09:05 PM
boosted k20
Jan 18, 2008 02:33 AM
1990hondadx
Jun 9, 2004 07:40 PM
sgT
Sep 19, 2002 08:31 PM
